It is currently Thu Aug 21, 2025 3:39 am
PostPosted: Wed Jul 12, 2023 8:43 pm
First name: Brad
Last Name: Combs
Hey folks,
I'm not sure who is still paying attention down here in this forum, but.... :)
I'm spending some cycles on learning how to create a side profile template. I see these from LMI, SM, etc... and many plans have them as well. The profile of the unbent side where along the edge of the side which will meet the back you have the taper and radius factored in already. I know you know what I'm taling about, but here is a video anyway - https://youtu.be/7oojobi72mE
There are a set of known dimensions, the unbent side length, the length of the box, the radius in question, neck block height, tail block height, etc... I'm expecting there is not a way short of modeling all this up to derive the profile to use for the unbent side. Is that correct? I didn't want to head down the rabbit hole of modeling it all up only to learn there is some easier way to arrive at that shape.
Note: I mean arrive at the shape on the computer. I'm aware of how to trace the shape with the mold using a washer and pencil, etc... what I mean is arrive at the shape in CAD.
Thanks!
Brad
PostPosted: Wed Jul 12, 2023 11:27 pm
I read it, Brad.
As a long time CNC guy, and there's no easy way - you gotta do the math. But sometimes it's hard to figure out what math to do. Good luck.
These users thanked the author Chris Pile for the post: bcombs510 (Thu Jul 13, 2023 10:18 am)
PostPosted: Thu Jul 13, 2023 10:19 am
First name: Brad
Last Name: Combs
Chris Pile wrote:
I read it, Brad.
Thanks, Chris!
Yeah, I’m expecting to have to model it all up. What I didn’t want was to get way down the rabbit hole and then have someone point me to R.M. Mottola’s online calculator or some such. :D
Brad
These users thanked the author bcombs510 for the post: Kbore (Sat Aug 31, 2024 9:47 am)
PostPosted: Thu Jul 13, 2023 11:03 am
First name: Marcus
Last Name: Bailie
City: Kirkland
I know some more advanced programs can do it, but I can't remember off the top of my head which ones. I think I remember reading that Fusion 360 can do it in "Sheet Metal" mode. I've been meaning to try it out for awhile.
-Marcus
http://www.bailieguitars.com
Instagram | YouTube
These users thanked the author Marcus for the post: bcombs510 (Thu Jul 13, 2023 11:36 am)
PostPosted: Thu Jul 13, 2023 5:31 pm
Use masking tape to tape up the side of one of your finished guitars and then peel it off. this will give you a flat pattern for the sides.
These users thanked the author Jim Watts for the post: bcombs510 (Thu Jul 13, 2023 9:18 pm)
PostPosted: Thu Jul 13, 2023 7:28 pm
First name: Leo
Last Name: Pedersen
City: Bowen Island
State: British Columbia
Zip/Postal Code: V0N 1G2
I can confirm that there are functions in Rhino3D to show the flattened version of curved surfaces. I'm guessing that most other CAD packages have similar functions. Which one are you using Brad?
But yeah those functions presume you already have the 3D model done.
These users thanked the author Durero for the post: bcombs510 (Thu Jul 13, 2023 9:16 pm)
PostPosted: Thu Jul 13, 2023 8:27 pm
That’s what I do too but I figured Brad
was talking about a new design.
These users thanked the author SteveSmith for the post: bcombs510 (Thu Jul 13, 2023 9:18 pm)
PostPosted: Thu Jul 13, 2023 9:18 pm
First name: Brad
Last Name: Combs
Yeah, I want the shape in CAD. It’s long winded, but suffice it to say I want to do more than just make a side template out of acrylic with the knowledge. :)
I’m using Fusion 360 and Marcus had me on the right path. I’ve got a set of steps using the sheet metal unfold approach. Working through it now.
Thanks all!
These users thanked the author bcombs510 for the post: Gasawdust (Sat Jul 15, 2023 8:19 am)
PostPosted: Tue Jul 18, 2023 9:18 am
Hi,
im pretty confident, that every decent CAD-App has commands for that kind of operation.
rhino has two commands to do that task, and I use them to do side-templates:
- one for a curve: CreateUVCrv
- on efor a surface: UnrollSrf
best regards
Chris
These users thanked the author 10WChris for the post (total 2): Durero (Thu Nov 21, 2024 3:54 pm) • bcombs510 (Wed Oct 02, 2024 6:14 am)
PostPosted: Wed Nov 20, 2024 4:15 pm
First name: Greg
Last Name: Holmberg
OK, it's over a year later, but maybe this will still help someone.
I model acoustic guitar bodies using onshape.com 3D CAD. It runs in your browser (so nothing to install) and is free to use. However, your plans will be visible to others and can be copied.
Here's an example body: a Martin OM.
This was modeled using the techniques proposed by R. M. Mottola and used in his "G Thang" tool. It is fully constrained (i.e. it won’t fall apart if you change something), and is also parameterized, so you can just change dimensions in the variable table, and the model will update.
In the model, I converted the surface of the sides to sheet metal, and then unwrapped the sheet metal to be flat.
From the flat view I converted and exported a DXF file, which I took to my local plastics shop (TAP Plastics), where they cut it out of 1/4" acrylic using their laser cutter. This was pricey, but now I have a template to route to with a trim bit.
I've since bought a CNC machine (a Laguna IQ 24x48), and I can cut my wooden sides directly. onshape is still working on their CAM module, but for now I'm using the free Kiri:moto plug-in to onshape to generate G-code for the CNC. It does the job.
Hope this helps,
Greg
These users thanked the author GregHolmberg for the post (total 2): bcombs510 (Sat Nov 23, 2024 11:45 pm) • Durero (Thu Nov 21, 2024 3:54 pm)
PostPosted: Thu Dec 05, 2024 9:47 am
First name: Richard
Last Name: Hutchings
City: Warwick
State: RI
Zip/Postal Code: 02889
Greg, how close do you cut your sides? I cut them to the line on my last guitar and it worked out great! I like to cut my blocks to size as well and now I can use my CNC for them as well.
I now have a CNC as well but could not cut that length without tiling.
Hutch
