It is currently Fri Aug 15, 2025 1:46 pm
PostPosted: Sat May 23, 2009 7:21 pm
Sort of an odd topic for a guitar building forum. What if you had an old rusty tailpiece that you wanted on your new guitar. Maybe your cleaning up an old Harmony for a neighbor and the tuner plates are a bit corroded.
So what do you do? You use electricity to remove the rust.
What you need:
A plastic container.
Water.
Washing Soda (not baking soda, there is a difference).
A steel plate, 16 gauge mild steel, no coating on this plate.
An automotive battery charger that will charge at 2 amps.
What you do:
Fill the plastic container with a solution of 1 tablespoon of washing soda per gallon of water.
Hook the negative lead from the battery charger to the rusted part and place it in the solution.
Attach the positive lead from the charger to the steel plate and put it in also. Don't let these touch, that will short out the charger.
Turn on the charger to 2 amps and wait.
Should take about two hours to remove light corrosion. Heavier corrosion will require a longer time in the bath.
When the rust is gone, wash the part in hot soapy water and dry it off.
This process will remove rust and most paints, lacquers, etc. It won't remove plating but if the part is rusted there is more than likely some plating missing in those areas. When washing the part after processing, use common sense. We used this process to preserve the original finish, so don't scrub with something that will scratch the surface. Also, the electrolysis works in line of sight between the part and the steel plate. If the part is rusted on multiple sides, you'll have to move it around in the bath to remove all the rust.
Here are some pictures of an old motorcycle header that I cleaned.
PostPosted: Sun May 24, 2009 8:11 pm
Man, that header looks great Steve!
What good information!!! [clap] [clap] [clap]
Okay now where do you get washing soda?
I definitely have a use for this info, that's not the only rusty tailpiece I have! :lol:
Thanks for the tute,
Joe
ps .... do you also have the info on a similar simple process for nickel plating? Say if I fashioned a tailpiece out of brass and wanted to plate it? .... backwoods poorboy
PostPosted: Sun May 24, 2009 10:25 pm
Washing soda will be found at the grocery store near the laundry detergent.
Plating kits can be found at Caswell Plating http://www.caswellplating.com/kits/ . They have nickel plating kits starting at about $35. They also have kits for plating copper, gold, chrome, cobalt, etc.
PostPosted: Mon May 25, 2009 5:59 pm
Last Name: Shaw
City: Philadelphia
Arm and hammer makes a washing soda called super washing soda. Its a detergent booster. I have seen it in the laundy detergent aisle at the super market.
PostPosted: Tue May 26, 2009 6:28 pm
First name: Mark
Last Name: Thorpe
City: Valparaiso
State: Indiana
You can do this to your old block planes that you pick up cheap. Good stuff Steve.
PostPosted: Thu May 28, 2009 12:24 am
Now I just need a tub big enough to fit my table saw in :D Or my Landcruiser laughing6-hehe
PostPosted: Thu May 28, 2009 12:53 pm
Last Name: Garrish
I've got some ideas on that one: http://trevorcook.typepad.com/weblog/2004/07/suv_takes_plung.html
Bob Garrish
PostPosted: Thu May 28, 2009 4:34 pm
Bob Garrish wrote:
laughing6-hehe laughing6-hehe laughing6-hehe
PostPosted: Fri Jul 03, 2009 8:59 pm
First name: Daniel
Last Name: Green
City: Milford
State: Ohio
Zip/Postal Code: 45150
Country: U.S of A
this method works great, done it many of times
It does leave pits but its still better then scaring the surface with steel
