It is currently Mon Apr 27, 2026 10:15 pm
 Post subject: Modified drill press
PostPosted: Sat Jul 20, 2013 1:50 am
First name: Martin
Last Name: Taylor
City: Central Coast
I have always had the problem that my drill press has too small a distance between where the drill comes down and the post of the stand. Of course, I could go out and buy a radial arm drill press but that is pretty expensive and as my wife asks (repeatedly) "can you justify sending the money on the cost of the next guitar?" To which my feeble reply is always along the lines of "Maybe... but it would work out better in the long run..." and then I put aside the idea for a later time. Well, the need suddenly arose and the finances weren't there so I decided to modify my existing drill press. Now, before you all cringe, the press I have is the cheapest, nastiest one that came from Aldi and cost $70 on special, so I figured if I destroyed it I would have a better excuse for replacement anyway. Anyway, the picture below shows my modification. I cut the steel post into two sections and remounted the base backwards on a shelf. I then mad a new base so I can still use the original metal base which can tilt etc. I can lower and raise the base and ended up cutting a hardwood wedge that holds it really tight. One day I will get the real thing but for now, this does work.
Martin Taylor
http://martintaylorguitars.com.au
These users thanked the author martintaylor for the post: Ron Bales (Sun Jul 13, 2014 9:34 pm)
 Post subject: Re: Modified drill press
PostPosted: Sat Jul 20, 2013 8:12 am
Necessity truly is the mother of invention:)
PostPosted: Mon Aug 12, 2013 5:49 pm
First name: D
Last Name: S
Clever! I just hand-drilled holes for string ferrules because my drill throat is too shallow.
My drilling did not go so well.
I made chop up my drill press like yours.
wah
Wah-wah-wah-wah
Wah
