It is currently Fri Jun 12, 2026 9:39 am
PostPosted: Sun Jun 24, 2012 6:19 pm
While it was raining like hell today I made this video. The background noise is the rain.
PostPosted: Sun Jun 24, 2012 7:52 pm
Online
Brilliant!
PostPosted: Tue Jun 26, 2012 3:40 pm
I've seen this somewhere before! (MIMF) Great job Chris. I love the simplicity of the construction and the outstanding results it delivers.
PostPosted: Thu Jun 28, 2012 7:37 am
Last Name: Flindall
City: Peterborough
Great video Chris! I always love watching your tutorial videos. I've learned a lot from them.
Rob
Rob Flindall
Flindall Guitars
http://www.flindallguitars.com
https://www.facebook.com/FlindallGuitars
PostPosted: Sun Oct 07, 2012 10:25 pm
Last Name: Chase
City: Ocean Beach
Zip/Postal Code: 11770-0174
The Jigmeister does it again!
A simple, elegant solution to a longstanding problem, and beautifully done.
Thank you for sharing this solution...
I am left with a question however.
What do you use to continue sanding things up to the fine grits so you can maintain your radii?
Thank you,
John Chase
PostPosted: Sun Oct 07, 2012 11:06 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
Great tut, Chris! I always learn a lot when I watch your videos. I have no mechanical background, so I would love to see how you modify a refrigerator compressor to be a vacuum pump!
PostPosted: Mon Oct 08, 2012 4:56 am
I think Shane has one here or search here for a discussion.
PostPosted: Sun Nov 25, 2012 11:29 am
First name: Britt
Last Name: Askew
Thanks for the video Chris.
I have not heard of this before so I searched for "refrigerator compressor vacuum" at youtube and there are lots of videos on the subject
PostPosted: Sat Dec 27, 2014 12:08 am
First name: David
Last Name: Eddy
City: Mandeville
State: La
Zip/Postal Code: 70448
Chris thanks for the inspiration
PostPosted: Sat Dec 27, 2014 12:37 am
Cool, nice job!
PostPosted: Sun Dec 28, 2014 5:40 pm
Nice if you have one, but you don't need a large stationary belt sander. The jig I designed along the same principle, and built about 2 years ago, is based on a hand-held beltsander (Makita 9924 DB). The only other difference is that instead of vacuum clamping I use double sided tape to hold the fretboard blank. Because of the limited length of the sander, the f.b. has to be moved back and forth over the jig which therefor has a total length of 1,15 m (45 1/4")
https://dl.dropboxusercontent.com/u/905 ... G_9314.JPG
The 3 parts to be assembled
https://dl.dropboxusercontent.com/u/905 ... G_9318.JPG
Close up of the jig's lower part
https://dl.dropboxusercontent.com/u/905 ... G_9317.JPG
Belt sander fitted, shop-vac connected
https://dl.dropboxusercontent.com/u/905 ... G_9316.JPG
Upper part fitted and height adjusted. Ready to be used.
PostPosted: Sun Dec 28, 2014 6:58 pm
First name: David
Last Name: Eddy
City: Mandeville
State: La
Henk,
That looks like it would work great!
That takes up less space than my sander, but I love my sander! It's funny how ideas change & flip-flop from one idea to the next! When I have trouble figuring something out, I turn it upside down and completely look at it another way! That looks like that's what you did!
