It is currently Sat Jun 06, 2026 4:57 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
 Post subject: Re: Types of glue to use
PostPosted: Mon Mar 02, 2015 7:50 am
+1 on leaving the liquid, bottled, Hide Glue on the shelf at the store - it's not the same as HHG by any means...
We all build at least slightly differently so glue choices are a personal preference thing as well as what's best for the job.
For all of time.... guitars have been built with the idea of serviceability which means building AND gluing in a manner that can be serviced into the future. HHG is great for this in so much as it can be released with heat and moisture and even reactivated and added to 50 years down the road.
Titebond original, not the II or III etc.
Here is a brief glance at what glues I use where and again others are likely using other glues in other ways - there is NO one accepted way to do most of these things.
Braces, bridge plate, bridge - HHG (the real stuff...)
Joining plates - HHG or Titebond and when I mention Titebond I always mean Titebond original
fret board to the neck - Titebond or quality epoxy. Headed back to Titebond for this after a good conversation with Link.
Blocks to the rim - Titebond
headplates - Titebond
linings - Titebond
bindings - Titebond
label - 3M spray stuff
rosette - Titebond (I use wood rosettes)
Neck to body including dovetail and extension - HHG or Titebond
When considering all of these different applications keep in mind what may need to be serviced in the future. A good example of this is that acoustics usually need a neck reset 10 - 40 years out so the glue should be serviceable such as HHG or Titebond.
An example of something that likely would not need to be serviced is the rosette and some folks use CA for this and the same holds true with bindings. I personally use Titebond for both rosettes and bindings and again it's some personal preference and sometimes application driven as well. I use wood bindings and rosettes so Titebond works for me.
Lots of stuff in the archives about glue including the penchant of Luthiers to fight over glue choices as well....;)
Haven't tried Titebond Extend but the name sounds like a commercial for an ED drug so I'm staying away from it.....
These users thanked the author Hesh for the post (total 2): SmilinBuddha (Sat Jun 27, 2020 11:35 am) • AR15DCM (Fri Mar 20, 2015 4:40 pm)
PostPosted: Mon Mar 02, 2015 2:34 pm
First name: kevin
Last Name: conlon
City: sligo
State: ireland
Zip/Postal Code: slig
Country: Ireland
All good advise from Hesh !!
Rusty
PostPosted: Sat May 16, 2020 5:19 pm
First name: John "jd"
City: Santa Barbara
Kinda funny that the spammers picked a glue thread...
PostPosted: Fri Jun 26, 2020 8:52 pm
Last Name: Howell
City: Atlanta
State: Ga
I make my perfling strips and glue up layers of wood for inlay etc. Also lay up bindings with several layers of veneer and hardwood.
Someone here recommended Tight bond III for this; heatproof and flexible. works great.
The white PVA glue like Elmers has an extended open time of 30+ min. I have used it over the years of other woodworking projects.
I have been experimenting with various glues for bindings as I read varied preferences expressed here and elsewhere.
HHG, Thin CA, yellow PVA: Now going back to HHG and change up process a little. I like the way you can heat it with heat gun and extend open time.
