It is currently Sat Jun 06, 2026 10:32 am
 Post subject: Carbide and oil
PostPosted: Sat Mar 07, 2009 10:26 am
Hi!
I notice some burnishers are made of H.S.Steel(Crown) and some like Blue Spruce states that it's made of carbide. Can someone share the difference?
Also, what oil do you use to burnish scraper so that it rolls easy?
Thanks, David
 Post subject: Re: Carbide and oil
PostPosted: Sat Mar 07, 2009 5:56 pm
First name: John "jd"
City: Santa Barbara
There is no significant difference other than the carbide will be harder to nick. either will work fine. An old screwdriver with no nicks in the shaft will also work fine.
I use either 3in1 oil or olive oil, whatever is sitting next to my workbench when burnishing scrapers. there is no magic, you just want the burnisher to slide smoothly and not tear the edge.
-jd
PostPosted: Sun Mar 08, 2009 9:28 am
Just make sure to wipe the oil off after you are done.
PostPosted: Sun Mar 08, 2009 12:42 pm
City: Santa Barbara
...and be careful not to cut your finger on the fresh edge while wiping off the oil.
(I figure if I type that out, maybe I will finally learn that lesson)
-jd
