It is currently Wed Jul 23, 2025 4:26 am
 Post subject: neck angle issues
PostPosted: Sat Dec 20, 2008 8:47 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
On my first build I am having issues with the neck angle. if I angle the neck flat and not following the angle on the upper bout then everything lines up. However if I attempt to angle the neck to match the upper bout then the straight edge will sit too high off of the bridge (which will require a very tall saddle to have workable action) however the problem is if I don't match the upper bout then there will be a gap between the fretboard extension and the soundboard. I think next time I will not sand the upper bout so much in the radius dish to avoid this problem in the future....
The problem is the only way that I can see to bring the action to usable level while matching neck angle to the upper bout is to shave the fingerboard or something or make a really big bridge. The gap is only visual (I hope) so I don't think playability is an issue... but it just looks so dammed ugly that you can see daylight through the fretboard extension and see the tenon and stuff...
Typhoon Guitars
 Post subject: Re: neck angle issues
PostPosted: Sun Dec 21, 2008 5:28 am
If I understand your problem correctly I think you might take a look at Hesh's tutorial about truing the upper bout. Seems to relate directly to what your problem is. Its in the archive of tutorials.
Warren.
PostPosted: Sun Dec 21, 2008 6:47 am
Such short memory spans laughing6-hehe I had this same problem two weeks ago:
viewtopic.php?f=10122&t=19963
I planed the top flat some and sanded the bottom of the FB extension some and now everything works out perfectly.
Good luck.
PostPosted: Sun Dec 21, 2008 7:58 am
Good Job Andy!!! [:Y:] [clap] [clap] [clap] [clap] [clap]
Tai Fu the taller bridge is a long walk down a short pier. Instead look at Andy's thread from last week and let us know if you have any questions?
PostPosted: Sun Dec 21, 2008 12:32 pm
The understanding of the geometry of the top is key. The more you build the more you learn. http://bluescreekguitars.com/blog/
this link may help you understand one of the many techniques to get the sides to help the top accept the geometry .
john
PostPosted: Thu Feb 26, 2009 3:17 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
So the cartridge sits in the neck pocket or heel which raises neck angle??
Typhoon Guitars
PostPosted: Thu Feb 26, 2009 3:35 pm
Cartrige???
PostPosted: Sat Mar 07, 2009 2:14 pm
Help!!! I can not get to Hesh's tut on Dome leveling anymore. I was at http://luthiersforum.3element.com/pages ... ng_jig.htm . That is a great write up!
Eddie Lee
PostPosted: Sat Mar 07, 2009 4:44 pm
John, without the head and tail blocks in don't the sides flex a lot when you are sanding? Is the pipe placed half way between the top end and bottom end of the body or at the highest point of the sides?
A higher purpose for wood.
Rich Smith
Issaquah, WA
PostPosted: Sat Mar 07, 2009 5:32 pm
Eddie, I might have saved a copy of Hesh's tutorial on my home computer. I'll look when I get home. In the mean time you might be able to glean what you need from this thread.
http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=20177
PostPosted: Sun Mar 08, 2009 12:15 pm
Eddie, I dug through my archived web pages and unfortunately that was one that I didn't grab. Sorry. Hope the other link helps.
