It is currently Sun Apr 26, 2026 3:58 pm
PostPosted: Sun Feb 01, 2015 4:46 am
Hi
Have dry fitted neck and all looks good, i have checked the height at bridge position and have 9mm with unfretted fretboard and 2.5mm with just neck. Fretted this will land ontop of bridge
Should i set the neck back a bit to allow for a bit of movement under string tension?
PostPosted: Sun Feb 01, 2015 7:25 am
This may help, posted in your other thread too: http://www.luthiersforum.com/forum/viewtopic.php?f=10102&t=15022%22
Over compensating neck angle is not advisable or necessary.
PostPosted: Sun Feb 01, 2015 7:26 am
Ok thanks hesh
PostPosted: Sun Feb 01, 2015 7:35 am
You are very welcome - some of the comments also will be helpful such as Colin's comment about backing the sandpaper with tape to help it keep from tearing.
These users thanked the author Hesh for the post: Cablepuller (Sun Feb 01, 2015 1:50 pm)
