It is currently Fri Apr 24, 2026 5:22 am
PostPosted: Wed Jul 14, 2010 6:00 pm
First name: sean
Last Name: loughney
City: lackawanna county
State: pennsylvania
i cant find any info on semi hollows. what do i need to know? is there a minimum thickness a top must be before carving?how do you do it? im sure i can carv a top once i practice.....but i need some guidance.
also, i will try and make this my last thread for a while.
thanks, and i really appreciate any and al info you people share.
-sean.
PostPosted: Fri Jul 16, 2010 6:52 am
First name: sean
Last Name: loughney
State: pennsylvania
Thank you for all the help, Chris.
By the way...... The Marlin is gorgeous!!
i tried to do wood binding on my latest build, but couldnt keep it from snapping around the horns. i guess the corners were too sharp to bend but not sharp enough to mitre.
PostPosted: Thu Jul 22, 2010 6:41 am
First name: sean
Last Name: loughney
State: pennsylvania
I think i have that bending iron...at least the one from stew-mac that i bought has multi-radius
So, "F-holes", when do i rout them...... before or after the carve? I mean it makes sense to me to do it before because of the flat surface. Or maybe I should invest in a scroll saw? Or could my dremel work? Do you suppose the palm and finger planes from Harbor Freight would suffice in carving my top? $150 for the ibex planes is kinda steep for me right now.
