It is currently Fri Apr 24, 2026 7:45 am
 Post subject: Baritone Fretboards
PostPosted: Sat Sep 25, 2010 9:35 pm
First name: Matt
Last Name: Mirando
City: Hamden
State: CT
Zip/Postal Code: 06517
Hello all!
I am new to the forum and very new to guitar building. I am working on a bolt-on body out of ash, and a neck-through out of poplar and oak. They are both my own body design and I can post pics of them if anyone cares to take a look.
Now to my question....
I am planing out a third build and have been toying around with the idea of building a baritone. I have a LARGE hunk of hard maple and a small amount of purpleheart to make another neck-through, and I was going to make it into a baritone. My problem is that I am not comfortable enough with fretwork yet to slot my own board, so I have been buying the Fender scale boards from Stew Mac. Is there anyone who sells the 28 5/8" scale boards preslotted? I found the bass scale (34") boards but that is way too much. Any advice on this would be appreciated!
Matt Mirando
 Post subject: Re: Baritone Fretboards
PostPosted: Sat Sep 25, 2010 9:41 pm
First name: matthew
Last Name: capeless
well whatever scall you are using if you bought one you could just copy the slots.
PostPosted: Sat Sep 25, 2010 9:47 pm
Cutting a 34" bass board at the 3rd fret will give you roughly 28 1/2" scale if I remember correctly and give you 21 frets with a pre-slotted board.
PostPosted: Tue Sep 28, 2010 9:37 am
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
Darell,
brilliant.
I never would of thought of that.
PostPosted: Tue Sep 28, 2010 8:21 pm
First name: shad
Last Name: peters
i could be wrong on this but i think lmii will do custom boards to whatever fretscale you want. might be worth checking out.
~shad peters
http://www.flickr.com/photos/petersinstruments/
http://petersinstruments.blogspot.com/
http://petersinstruments.com/
PostPosted: Mon Oct 11, 2010 11:38 pm
alot of scales used as a standard are based off a 34 inch bass scale. you can also get a 25.5 fender scale out of it using the 5th fret as the nut......its why im building this with 29 blades.....i can do a 34 scale with 29 frets, a 28.6 baritone with up to 26 and a fender scale with 24.........and everyone said "why do that, all that work and youre stuck with one scale....... :lol:
PostPosted: Mon Oct 11, 2010 11:41 pm
alot of scales used as a standard are based off a 34 inch bass scale. you can also get a 25.5 fender scale out of it using the 5th fret as the nut......its why im building this with 29 blades.....i can do a 34 scale with 29 frets, a 28.6 baritone with up to 26 and a fender scale with 24.........and everyone said "why do that, all that work and youre stuck with one scale"....... :lol: i can even get smaller scales in between that ive used for a mini guitar or bass (travel size)
PostPosted: Tue Oct 12, 2010 8:14 am
And I thought it was just some new-fangled torture device for S&M fanatics! :lol:
Joe
