It is currently Fri Apr 24, 2026 3:41 am
PostPosted: Mon Mar 23, 2009 3:51 pm
First name: shad
Last Name: peters
first off i was wondering if anyone on here had ever used square aluminum rod as reinforcement in a bass neck instead of carbon fiber strips. i had some that is a 1/4 in sqaure and would offer a lot of support but i wasn't sure if it had any kind of negative qualities i should be aware of.
secondly what kinda action should i shoot for on a fretless bass? has anyone on here ever set on up before?
~Shad Peters
~shad peters
http://www.flickr.com/photos/petersinstruments/
http://petersinstruments.blogspot.com/
http://petersinstruments.com/
PostPosted: Mon Mar 23, 2009 3:53 pm
Square aluminum bar will weigh too much and will retain flex memory.
PostPosted: Mon Mar 23, 2009 5:05 pm
First name: shad
Last Name: peters
well actually aluminum is a very light material almost as light as carbon fiber, but when you consider that and aluminum bike frame compared to a carbon bike frame might have a difference of a pound at most between them on something as small as a support rod you wouldn't even be able to tell the difference.( i don't mean to sound snooty but i have done some research and also do a lot of work with aluminum and other metals) and as far as the memory of the metal its not much different than steel it just depends on the grade of the metal, but unless i build an incredibly horrible instrument the neck shouldn't ever bend so much that the aluminum doesn't have the memory to snap back (they wouldnt make aircraft from it otherwise). i mean like i said correct me if im just totally off base or something, but I'm fairly confident in its ability to strengthen the neck i am mostly worried if it would have bad tone qualities or something of that nature.
shad peters
~shad peters
PostPosted: Tue Mar 24, 2009 4:14 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Warmoth uses steel reinforcement bars in their bass neck, it works but it does weight a bit more, but not enough to throw the bass off balance unless you use very light body wood.
Typhoon Guitars
PostPosted: Tue Mar 24, 2009 7:33 am
First name: Stephen
Last Name: Ziegenfuss
City: Jackson
I just started using 3/32 x 0.25" steel reinforcement rods in my necks and love the results. The neck is bright and alive everywhere, and is consistently stiff. I use a heavy cutaway design that creates a torsional loading on the neck. Without heavy reinforcement, it is a bear to set up...
Some of the big names, like Pedulla use steel in there necks as well, after trying CF and Aluminum, they settled on steel because it seemed to be the most consistent in strength and energy transmission.
Stephen
www.ziegenfussguitars.com
PostPosted: Tue Mar 24, 2009 7:45 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
The benefit of steel is that they're cheap, and not such a pain to work with like CF. I could buy steel rods from any shop and use that instead of paying inflated prices plus shipping and tax.
Typhoon Guitars
PostPosted: Tue Mar 24, 2009 10:46 am
Last Name: Garrish
Aluminum is not nearly as stiff in cross section as steel or carbon fiber, but it is as stiff pound for pound (as steel). Essentially, you'll have to use a piece of aluminum 3x as wide (and of equal height) to get the same stiffness (and mass) as a piece of steel. When considering the shape of a guitar neck in cross-section, you can fit a much taller (stiffer) piece of steel in there comfortably than an equivalent piece of aluminum, and you'll displace less wood.
Bob Garrish
PostPosted: Wed Mar 25, 2009 1:40 am
First name: Brett
Last Name: Faust
City: Puyallup
Zip/Postal Code: 98373
You can get titanium from KTS and it costs less than CF usually.
PostPosted: Wed Mar 25, 2009 10:56 pm
Which KTS is that? I only see bridge parts on their site.
Regarding alu, I would opt for 1/4 x 3/8" or even 1/2" if it will fit in your neck. A 1/4" rod layed just under the fingerboard would be pretty close to the neutral axis so would not likely do much good.
PostPosted: Thu Mar 26, 2009 1:31 am
First name: Brett
Last Name: Faust
City: Puyallup
Hi Sheldon, You had the correct site but you have to contact them to specify size. They also make titanium truss rods as well. Look under custom shop on the web site.
Hope that helps [:Y:]
PostPosted: Fri Mar 27, 2009 8:45 am
First name: shad
Last Name: peters
thanks everyone your comments were all really helpful [:Y:]
~shad peters
PostPosted: Tue Mar 31, 2009 9:42 am
Thanks Brett, I'm going to give some a try.
PostPosted: Wed Apr 01, 2009 1:38 am
Last Name: Shaw
City: Philadelphia
The difference between aluminum and carbon fiber is that the carbon fiber has some spring back. It is rigid but if it is bent in a neck it doesn't retain that bend like aluminum can. Steel also has spring back ability to a point. A lot more then aluminum.
