It is currently Fri Apr 24, 2026 3:59 am
 Post subject: trussrod question
PostPosted: Tue Jul 07, 2009 5:40 pm
First name: Andrew
Last Name: Dutton
City: Bakersfield
Zip/Postal Code: 93308
So I've got the scarf joint set and am ready to route the channel for the trussrod, which I have yet to order. the length of the neck from the butt of the nut to where the guitar will meet the body is 15 1/4", my question is how long of a trussrod will I need to make this work? All help is appreciated. Thank you!
 Post subject: Re: trussrod question
PostPosted: Wed Jul 08, 2009 10:44 am
First name: Stephen
Last Name: Ziegenfuss
City: Jackson
Andrew,
generally, you just order a truss rood to the type of guitar you are building. For example, even though I use a high neck to body joint on a singlecut bass (almost at the 12th fret), I still use a full bass truss rod. Where the neck is joined to the body, it is fully constrained, but where it is free, it is free and will operate accordingly.
Stephen
www.ziegenfussguitars.com
PostPosted: Wed Jul 08, 2009 4:06 pm
First name: Andrew
Last Name: Dutton
City: Bakersfield
Ok, thank you. That makes sense, though I think I am going to set this neck aside and maybe use for a cg build later on. I decided that it was to short after comparing to the body template.
