It is currently Mon Jul 28, 2025 4:07 am
 Post subject: Back Bow Help?
PostPosted: Fri Oct 23, 2009 2:16 pm
First name: Stephen
Last Name: Ziegenfuss
City: Jackson
I need some help:
1. I have a neck for a new bass that has ever the slightest amount of back bow in it, after fretting.
2. Typically, I use a double acting truss rod to correct this before fret leveling.
3. I went to 'loosen the truss rod' to straighten the neck and the truss rod nut just came loose - bad weld or something.
4. Is there any way to straighten the neck so I know I will have to add back back to the system after strings are installed, or should I try to yank the rod?
Stephen
www.ziegenfussguitars.com
 Post subject: Re: Back Bow Help?
PostPosted: Fri Oct 23, 2009 2:40 pm
I don't have experience with the truss rod situation, but have you tried just putting strings on it to see if you get enough neck relief that way?
Joe
PostPosted: Fri Oct 23, 2009 3:19 pm
It seems if the truss rod has failed, it needs to come out regardless of how straight or bowed the neck is.
