It is currently Mon Apr 20, 2026 6:40 pm
 Post subject: Finish Questions
PostPosted: Mon Feb 01, 2010 4:06 pm
First name: Britt
Last Name: Davis
City: Monroe
State: GA
I really want to be able to apply a Black flametop finish on my
strat. Similer to that of the Epiphone LP Bass shown here.
How do I do that? Does it need to be made of a certain type of wood?
 Post subject: Re: Finish Questions
PostPosted: Mon Feb 01, 2010 4:09 pm
Top needs to be curly maple first wetted to rais the grain stained with black taranslucent dye then wipped off. the black will impregmate the curl of the grain. then lacure is tinted with a red translucent dyy and sprayed over the the maple. the the final coats a re clear/
Last edited by Michael Dale Payne on Mon Feb 01, 2010 4:14 pm, edited 1 time in total.
PostPosted: Mon Feb 01, 2010 4:13 pm
First name: Britt
Last Name: Davis
City: Monroe
State: GA
Dang...
I was hoping to apply it to a restoration, but its built with Ash...
PostPosted: Mon Feb 01, 2010 4:15 pm
Britt wrote:
Dang...
you can do the same thing but the pattern will not be tiger stripped it will be what ever the grain pattern of the ash is
PostPosted: Mon Feb 01, 2010 4:19 pm
First name: Britt
Last Name: Davis
City: Monroe
State: GA
Ok, well on that case then another question.
The guitar itself is a sunburst, I haven't started sanding yet but
my dad told me I wont have to sand all the way to the wood, just
past the top layer of clear coat.
Do I or do I not?
PostPosted: Mon Feb 01, 2010 4:22 pm
if your are trying to leave the sunburst on it that is harder than it seems. Typically the color is in the finish darker closer to the top of the finish and lighter closer to the seal coat so if the intent is to get rid of the sunburst you need to sand to the wood. the seal coat is very thin and it is just simpler to sand to the wood.
PostPosted: Mon Feb 01, 2010 4:24 pm
First name: Britt
Last Name: Davis
City: Monroe
State: GA
Ok, thanks Michael.
PostPosted: Tue Feb 02, 2010 10:39 am
Last Name: McGee
City: Belleville
State: Illinois
Just as an FYI....
This is an ash body I applied black stain to then sanded back. You can see that the wood between the grain is darker than normal un-dyed ash. When I tried to sand back enough so that this was clear & bright, I started losing significant amounts of grain definition. In the end, I re-stained and sanded back to what you see here.
So just a heads-up - if you're going to be doing it on ash, then you WILL have some serious darkening of the surrounding wood.
Bad decisions make for good stories.
-------John
My blog - http://poplarmechanics.blogspot.com/
PostPosted: Tue Feb 02, 2010 8:55 pm
Sweet, John. I've got to try that sometime.
PostPosted: Wed Feb 03, 2010 3:43 pm
First name: Britt
Last Name: Davis
City: Monroe
State: GA
I have decided to go with a silver burst finish. Its something I really liked
but hadn't thought of at the time.
