It is currently Fri Jul 18, 2025 12:24 pm
PostPosted: Thu Mar 25, 2010 2:59 am
Country: Scotland
finished drawing sharktooth inlays & sorted through pieces to use and come across one piece that catches the light very well,
my only prblem with this is after i put it into the fingerboard i have to sand it. knowing that i may loose the pattern.
is there anyway of getting around this? will be inlaying on a 12" rad with 1.5mm thick MOP.
if i can get a pic up of the piece sometime today i will.
thanks
PostPosted: Thu Mar 25, 2010 8:51 pm
Last Name: Garrish
Outside of using Gravlam, or slicing the piece up into multiple slivers and reconstituting it into a radiused piece, you pretty much have to hope for the best when sanding a bunch off of a piece of shell.
Bob Garrish
