It is currently Fri Jul 18, 2025 5:12 pm
PostPosted: Wed Jul 21, 2010 5:13 am
Country: Scotland
as the title.
i have CCL gunstock oil. would this do??
also. the fingerboard has some slight brown streaks in it. what stain would i use to get around this.
thanks
PostPosted: Wed Jul 21, 2010 6:20 am
Last Name: Thiessen
City: Lexington Park
Stew Mac has a black fingerboard stain that will make it all black. As for sealing it, I use the colortone fingerboard oil from Stew Mac. I use Tru-oil on the back of my necks but not on the top of the fret board. I can't remember why but somewhere I read that you shouldn't use the gun stock oil on rosewood or ebony type fingerboards.
John Thiessen
http://www.iszacguitars.com
PostPosted: Wed Jul 21, 2010 1:00 pm
First name: Stuart
Last Name: Gort
If that's really true I would like to know why......can't remember where you heard that? Think. Think. :)
StuMusic
PostPosted: Wed Jul 21, 2010 3:06 pm
Last Name: Thiessen
I remember what I was thinking, it shouldn't be used on cocobolo at all due to the oils in the wood (I did 4 cocobolo fretboards in a row). As for using on the fingerboard, it is fine to use on rosewood and ebony, but generally not done on the top of the fret board because tru-oil builds up, and then will get worn easily from the strings etc. It would probably be fine though if you put it on very lightly and not let it build up. I have always used it on the sides of the fretboard when I do the neck in tru-oil.
John Thiessen
PostPosted: Thu Jul 22, 2010 2:47 am
I've had situations where the true oil wouldn't dry, mainly cocobolo, but sometimes other woods as well. For instance I've used it succesfully on some guitar bodies made of Padauk, but then other Padauk pieces it wouldn't dry on them. I stopped using tru-oil altogether as it seems to be unpredictable and unreliable for me.
Old growth, shmold growth!
PostPosted: Thu Jul 22, 2010 5:33 am
Country: Scotland
gunstock oil still out the window?
PostPosted: Thu Jul 22, 2010 7:09 am
Last Name: Thiessen
My experience with Tru-Oil has led me to put it on as thin as possible. I have never had a problem with it drying as long as I do that. I used to try and see how thick I could get one coat without it running, but it became very unpredictable and a mess. I basically follow the directions on the bottle, and not what it on LMI's website. I use it directly on the wood with no other sealers or anything else, and put a little bit on a rag, start wiping it on the wood and keep wiping until it is no longer spreading the oil around (very thin layer). The only wood it hasn't dried to was cocobolo, I have never attempted paduk though. On my necks I use 4 or 5 coats like this and then put some wax on it. I have had great success over maple, walnut, jatoba, lacewood, african mahogany and redwood.
John Thiessen
