It is currently Wed Jun 10, 2026 6:45 am
 Post subject: Guitar neck sanding
PostPosted: Fri Sep 03, 2010 1:55 am
I want to sand the beck of the neck on my Stratocater to make it a bit smoother. At the moment the finish is a bit sticky.
What grits of sand paper should I use? Wet sand?
Thanks guys!
 Post subject: Re: Guitar neck sanding
PostPosted: Sat Sep 04, 2010 10:42 am
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
try 600 grit, wet, and see what happens.
if that does the job, go to automotive polishes,
if not, go to 400 grit and work back up to the 600 and then to the polishes.
don't wear thru da finish!
