It is currently Sun Apr 26, 2026 5:42 pm
PostPosted: Tue May 17, 2011 2:38 pm
Last Name: morciglio
City: waterford
State: michigan
Zip/Postal Code: 48327
Just got this one mocked up!
Wired the top to check before gluing the halves up.
Wanted to see IF I need a sounpost or toneblock to reduce feedback.
Very happy with the GFS Classic alnico 2's. Have a set of Stewmac Parsons I was going to try before glue-up, but I'm just going to save those for the next build.
This one's a KEEPER! Blown away with the tone and vibe from this deep build.
Still need to crank more volume before deciding if the feedback is too much.
Thanks for looking.
JM
PostPosted: Tue May 17, 2011 2:44 pm
How thin is the carbon fiber on your guitars?
Did you make the molds?
Did you handlay the cloth?
Pre-preg, or add your own resin?
Are you using heat and vacuum to cure, or autoclaving?
Tell me all about it!
PostPosted: Tue May 17, 2011 2:46 pm
City: waterford
State: michigan
Not sure why the same pic posted twice?
Used a Warmoth neck on this one, again, gun-shy on going straght to carbon molds. Actually like the profile on the Mighty-might better.
On to full carbon molds!
One of those?
JM
PostPosted: Tue May 17, 2011 2:55 pm
City: waterford
State: michigan
Chris;
.039 or 3 layers of 6K twill weave.
Yes I make the molds. ( this was a quicky with same single mold used for top and bottom with bolt-on necks).
Vacuum bagged w/ eboxy resin. Pre-pregs need to be refridgerated and don't like to conform to complex shapes unless you have VERY deep pockets.
This has been an experiment to see if I can build a high quality (soundwise) intrument with carbon.
Could not be happier bliss with the results so far.
Planned to build a third with mahogony neck/toneblock, but decided to go straight to full neck/body, seperate top, molds. Then try some more combinations.
PostPosted: Tue May 17, 2011 4:52 pm
Very cool stuff.
Plan to make any necks?
cron
