It is currently Fri Aug 01, 2025 10:00 pm
 Post subject: My First Carved Top
PostPosted: Sun Jul 10, 2011 9:35 pm
First name: Brad
Last Name: Broomfield
City: Edmond
State: oklahoma
Zip/Postal Code: 73025
Country: United states
I finished up my first carved top body today, i think it came out fairly well. I used the topigraphical routing and sanding technique. The guitar is getting close.
 Post subject: Re: My First Carved Top
PostPosted: Sun Jul 10, 2011 10:53 pm
City: LV
State: NV
What a pleasing shape. [:Y:] A familiar single-cut mood with a hint of soloist.
Off to a good start!
PostPosted: Sun Jul 10, 2011 10:58 pm
First name: Brad
City: Edmond
State: oklahoma
Thanks guys, does anyone have a good way to make the bowl type spots for the control knobs? I used a router cove bit bit in the drill press but was less then impressed. Im open to ideas.
PostPosted: Mon Jul 11, 2011 8:43 am
First name: Jonny
Last Name: D
Take a drill bit the same size as your holes for the pots....
drill thru a pice of 1" diameter wood rod....
glue the rod to the drill bit.... about 1/2 way up....
once glue is dry put the drill bit into the drill press and spin it....
use a rasp or sand paper on a block to shape the wood rod to any shape you'd like.
then glue small strips of sandpaper to the wood block... works like a charm and it's cheep... it'll really only cost you a drill bit..... + you can shape it any way you'd like... from a very soft U to a hard V with a flat on the bottom... anything goes....
Users browsing this forum: Bing [Bot] and 3 guests
