It is currently Fri Sep 19, 2025 9:05 pm
 Post subject: Pickup ring
PostPosted: Wed Nov 23, 2011 11:58 am
First name: David
Last Name: Schneider
City: Silvis
State: IL
Zip/Postal Code: 61282
Does anyone know if the Stewmac Strat pickup ring for single coil will work for an EMG Select model SES pickup?
 Post subject: Re: Pickup ring
PostPosted: Wed Nov 23, 2011 6:29 pm
It should but the EMG pickups usually have square bottoms below the mounting ring. The mounting ring will work for the pickup definitely, but you will have to check the guitar cavity to make sure the pickup fits the body cavity when the ring is installed, and you may need to excavate wood for that.
Old growth, shmold growth!
PostPosted: Wed Nov 23, 2011 8:28 pm
First name: shad
Last Name: peters
verhoevenc wrote:
I wouldn't imagine why not? Strat-style single coils usually follow the same size specs. It wouldn't make much sense to build after market pickups that aren't direct replacements.
Chris
Its a legitmate question (one that I dont know the answer to) I have had emg humbuckers that would not fit standard pickup rings without filing them down. for some reason the covers are just larger on emg pickups.
~shad peters
http://www.flickr.com/photos/petersinstruments/
http://petersinstruments.blogspot.com/
http://petersinstruments.com/
PostPosted: Thu Nov 24, 2011 5:59 am
First name: David
City: Silvis
State: IL
Is there a standard dimension for screw spacing and length and width of the pickup?
