It is currently Fri Apr 24, 2026 11:05 pm
PostPosted: Fri Jan 13, 2012 12:52 am
First name: Gabby
Last Name: Losch
City: Brookline
State: MA
Hey all. I'm in a bit of a bind here. Finishing up a custom Telecaster for a customer and the electronics are buzzing like crazy. I'm using a Superswitch (5 way) for a humbucker in the neck, and stacked Tele bridge pickup. There's signal coming out in all 5 positions, and I hear the tone changing but the buzz is there in all positions, and overpowers the guitar signal. I'm using a wiring diagram that was made for me by a member on TDPRI, and I double checked the connections to make sure I have it accurate to that diagram. Here's what it is:
http://www.tdpri.com/forum/tele-technic ... ost3848100
Anyone know why this wouldn't work? I was supposed to deliver the guitar on Saturday, so obviously I'm really short on time to figure this out. Any help would be HUGELY appreciated!
PostPosted: Fri Jan 13, 2012 1:02 am
First name: Gabby
Last Name: Losch
City: Brookline
State: MA
Just plugged it back in and discovered that when I touch the strings it buzzes louder, and when I touch the output jack the buzz lessens.
PostPosted: Fri Jan 13, 2012 1:16 am
Sounds like a grounding problem to me....
PostPosted: Fri Jan 13, 2012 1:28 am
First name: Gabby
Last Name: Losch
City: Brookline
State: MA
Hey Chris,
That's what I think too, but do you have an idea of where the grounding issue might be? I might just desolder all the wires that are currently grounded to the pots, and just redo the connections. There are a lot of wires grounded to the volume pot. Maybe one of them isn't making a solid connection?
PostPosted: Fri Jan 13, 2012 1:42 am
First name: Daniel
Last Name: Wotton
City: Old Toongabbie
Zip/Postal Code: 2146
Is the wiring earthed to the bridge or tailpiece?
PostPosted: Fri Jan 13, 2012 1:55 am
First name: Gabby
Last Name: Losch
City: Brookline
State: MA
This is the bridge pickup I'm using: http://www.seymourduncan.com/products/e ... e_stack_f/
It should have a grounded plate. I also connected a separate bridge ground. Is it possible that those are interfering with each other?
PostPosted: Fri Jan 13, 2012 2:14 am
First name: Gabby
Last Name: Losch
City: Brookline
State: MA
Crisis averted. Stupid mistake of course. I wired the output jack backwards. I was so busy looking at the control plate, I forgot to recheck the jack.
Thanks for the suggestion Chris!
Users browsing this forum: No registered users and 91 guests
