It is currently Sat May 02, 2026 5:47 pm
PostPosted: Tue Mar 06, 2018 3:27 pm
First name: Conor
Last Name: Searl
City: Duncan
State: British Columbia
Zip/Postal Code: V9L 2E5
I'm about to jump into my first set neck build. Is it best practice to finish the guitar once the neck is glued or while the body and neck are still separate?
PostPosted: Tue Mar 06, 2018 4:17 pm
It's done both ways. There are benefits and trade-offs to both approaches.
PostPosted: Wed Mar 07, 2018 8:37 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I have concluded for myself that finishing after the neck is set gives the best results in the best time.
No worries about the cheeks of the heel not matching the body due to finish build, no rebuffing after setting the neck, no worries about keeping finish off the joint surfaces (less masking and no chips from pulling the mask).
Brian
These users thanked the author B. Howard for the post: Conor_Searl (Wed Mar 07, 2018 11:59 am)
PostPosted: Wed Mar 07, 2018 12:02 pm
First name: Conor
Last Name: Searl
City: Duncan
Thanks Brian, that confirms some of my initial suspicions. I've only done bolt-on's so far, so I've always just attached a holder onto the end of the neck and into the neck pocket to hang the guitars to dry and give me something to hold on to or hang when I'm painting. What's the best way to accomplish this with what amounts to a complete guitar?
PostPosted: Tue Mar 13, 2018 9:26 pm
First name: Freeman
Last Name: Keller
On most set neck guitars the curve of the cutaway(s) blends into the neck heel. If you finish them separately you will not be able to sand them perfectly flush and there will always be a seam between the two parts. You almost never want to take this apart (unlike both an acoustic or a Fender style joint).
So unless you are using different finish materials or colors I would suggest finishing neck on.
