It is currently Fri May 08, 2026 4:34 am
 Post subject: Veneering pick guards
PostPosted: Thu May 17, 2018 1:42 pm
First name: Freeman
Last Name: Keller
I just veneered two headstocks for a customer and there is a lot of veneer left over. We've decided to apply it to pick guards so they will match. I have lots of black plastic p/g material, my idea was to cut out the guards, glue the veneer on as I did on the heads and shoot a few coats of lacquer. Question is, what kind of adhesive would be best here (I used Titebond on the heads)? (And I'll make myself a note to be sure to remove the film before I do it). Veneer is 0.020, I don't have any sort of vacuum so I'll probably be clamping between something flat - maybe 3/4 MFD
PostPosted: Thu May 17, 2018 2:40 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Do you have enough veneer to lay up a few layers with epoxy and make the pick guards from that?
Bryan Bear PMoMC
PostPosted: Thu May 17, 2018 4:42 pm
Titebond always worked for me doing veneer applications.
PostPosted: Thu May 17, 2018 6:55 pm
Last Name: Sollod
Does titebond adhere to plastic? What about contact cement? I'll be interested with what you decide to use. ...and how it worked.
www.swiftcreekguitars.com
PostPosted: Thu May 17, 2018 7:00 pm
Last Name: Sollod
How about Duco or Stew mac Bind-all? Works for plastic binding...
PostPosted: Fri May 18, 2018 6:06 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I would go with a contact cement like used for P-Lam counter tops.
Brian
These users thanked the author B. Howard for the post: Durero (Fri May 18, 2018 2:37 pm)
PostPosted: Fri May 18, 2018 10:21 am
First name: D
Last Name: S
I’ve used Bryan’s suggestion with good results.
3-5 layers of veneer glued with veneer glue.
The finished piece is durable, machinable, and somewhat flexible.
wah
Wah-wah-wah-wah
Wah
