It is currently Wed Jul 23, 2025 9:02 am
PostPosted: Thu Aug 08, 2019 11:53 am
First name: Conor
Last Name: Searl
City: Duncan
State: British Columbia
Zip/Postal Code: V9L 2E5
I'm unsure on how to achieve a finish like this. Black lacquer, under very thin satin clear? Would a person cut and buff this finish the same as usual, or would one need it to be perfect right off the gun?
PostPosted: Fri Aug 09, 2019 3:36 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Wood is ash, that is important. Need a heavy grain to get the look. Spray with black base coat and then run satin clear. Yep, satin finishes must be clean off the gun with no texture or dust seeds. No cut and buff on a satin finish.
Also of note is the incredibly low gloss factor of this finish in particular..... I'm guessing this was done in a 2K urethane flat system that is popular with the hot rod set these days as I know of no wood finish this low in gloss.
Alternatively you could run a epoxy surfacer/primer in flat black and call it a day but still gotta be great off the gun.
Brian
These users thanked the author B. Howard for the post: Conor_Searl (Fri Aug 09, 2019 5:26 pm)
