It is currently Fri Sep 19, 2025 1:38 pm
PostPosted: Fri May 29, 2020 1:59 am
First name: Dan
Last Name: Shutt
To those who build children's or half size guitars: where do you get your truss rods?
I'm looking for a 350–365mm truss rod for a build and the only option I've found is a dual action mandolin rod but it's through ebay and comes from China, so isn't ideal.
I'd happily build my neck to match a trust rod if they're so elusive but perhaps you have some ideas.
PostPosted: Fri May 29, 2020 7:55 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
Martin 12 fret rod or from this supplier https://www.bitterrootguitars.com/Home-Luthier-Products-Truss-Rods-s/1914.htm
Fred
Fred Tellier
PostPosted: Fri May 29, 2020 10:47 am
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
One of the reasons I switched to Mark Blanchard for truss rods is that he’ll make them any length you want — all same price.
Not the cheapest rods, but arguably the best on the market:
http://www.blanchardguitars.com/guitarpages/truss_rods/truss_rods.html
PostPosted: Fri May 29, 2020 10:54 am
First name: David
Last Name: Schwab
City: Staten Island
Zip/Postal Code: 10201
Here’s a 12” double action rod.
https://www.lmii.com/truss-rods/2387-tr ... th-13.html
PostPosted: Fri May 29, 2020 1:34 pm
City: Escondido
Zip/Postal Code: 92029
Or not at all. If you use regular tuning on a guitar with 18" scale length, your string tension goes way down. You end up with tension closer to a classical guitar and less length to bow. If you are concerned, a single 1/8" x 1/4" carbon fiber rod should be enough to keep the neck straight. You can cut those to any length you need.
PostPosted: Sat May 30, 2020 5:12 am
First name: Dan
Last Name: Shutt
Thanks for the answers, that's what I needed to know. I wasn't aware of the concept of a 12-fret truss rod and if I only need a carbon fibre reinforcement rod then I can save a little time in making a truss rod nut accessible and streamline the headstock design too.
