It is currently Sun Jun 15, 2025 7:21 am
 Post subject: Carbon Fiber rods
PostPosted: Wed Mar 05, 2014 11:18 am
Can anyone tell me if the carbon fiber material they make archery arrows with is the same strength as material typically sold at Stew mac etc.. If it is, do you think the round shape if seated in a core box routed channel covered with a wood fillet would be good.
I am trying to straiten a cheap mandolin neck with alot of upbow, remove the finger board, plane out bow, and rout and epoxy CF etc.. needless to say no truss rod in it.
I have a cheap source of old arrows locally.
thanks
rasby
These users thanked the author frwilliams for the post: jayluthier (Sat Oct 01, 2016 2:35 pm)
 Post subject: Re: Carbon Fiber rods
PostPosted: Wed Mar 05, 2014 12:28 pm
Well, carbon fiber in any form is pretty strong.
I'd say using an old arrow for a truss rod is pretty good recycling.
Let us know how it turns out.
PostPosted: Wed Mar 05, 2014 5:14 pm
First name: Big
Last Name: Jim
Bound to be stronger than it is now . I always use square myself but dont see any reason it wouldnt work round. I agree with Chris , Let us know how it goes .
PostPosted: Thu Mar 06, 2014 9:02 am
City: chicagoland
State: illinois
the rods used in guitar making are solid; i'm assuming the arrows are hollow, with very thin walls. strong enough for an arrow, but......
PostPosted: Thu Mar 06, 2014 8:50 pm
First name: Big
Last Name: Jim
Good point , that could make a difference . You can buy the stuff fairly cheap to btw . I use http://www.dragonplate.com/
PostPosted: Mon Mar 10, 2014 1:20 pm
First name: Lee
Last Name: Passmoor
City: Newport Pagnell
State: Bucks
Zip/Postal Code: MK16 8JG
Country: United Kingdom
Buying carbon bar of an appropriate size is tricky in the UK but I have bought some square bars, one with a 6mm OD and a 4mm ID, the second with a 4mm OD and a 2.5 mm ID. The smaller rod is a nice fit inside the larger one and my intention was to glue the two together to make a nice strong truss rod. What would be the best glue to bond the two together? Can I use thin CA and wick it down or do I need to use an epoxy glue and hope I don't scrape it all off when I slide it in?
PostPosted: Mon Mar 10, 2014 4:48 pm
I would think either will work. CA isn't very shock resistant, but that shouldn't be a problem buried in the neck. Epoxy is relatively stable, although it might creep under high heat - but again shouldn't be a problem.
I am pretty interested to see how this works for you. I like the idea of re-purposing broken stuff in unusual ways.
PostPosted: Mon Mar 17, 2014 5:42 pm
I have not yet used the arrow, but it is solid as opposed to hollow. Still thinkin on it.
thx for replies
PostPosted: Mon Mar 17, 2014 6:49 pm
What's the holdup?
Go for it.
PostPosted: Mon Mar 17, 2014 9:59 pm
City: chicagoland
State: illinois
must be very expensive/heavy arrows. i think the solid ones are used for bowfishing
PostPosted: Tue Mar 18, 2014 4:28 pm
First name: Big
Last Name: Jim
I have used Gorilla glue to put in several and it seems to work well . The one thing I found that helps is to lightly sand the carbon ruffing it a bit and it sticks better
PostPosted: Mon Jul 21, 2014 9:08 pm
First name: William
Last Name: Stewart
City: West Chazy
State: New York
Zip/Postal Code: 12992
If anyone is looking for inexpensive carbon fiber, in the past, walmart locally as well as the box sporting goods stores sell solid cf arrows for children. Have cut into them, and they are completely solid. Great price and no shipping.
These users thanked the author wrstew for the post: Lonnie J Barber (Wed Jul 23, 2014 10:52 am)
PostPosted: Tue Jul 22, 2014 1:09 am
First name: Jeff
Last Name: Dillard
Make sure there's no rattle before putting the fingerboard back on
Users browsing this forum: No registered users and 42 guests
