It is currently Sat Jun 14, 2025 9:33 pm
PostPosted: Mon Apr 04, 2016 11:35 am
Last Name: Blower
City: Keighley
State: West Yorkshire
Country: UK
Since I've only made steel string guitars before with domed soundboards and a slight neck angle, this was my initial thought when planning the u bass project.
My question is, is this necessary on a low tension instrument like the u bass?
Can I leave the soundboard flat and have a straight neck as per a classical guitar?
What is the norm folks?
Steve.
PostPosted: Mon Apr 04, 2016 1:27 pm
Last Name: Reed
City: Stowmarket
State: Suffolk
Zip/Postal Code: IP14 2EX
Country: UK
On a uke I usually use a flat top, though Martins had a slight dome and some of the top makers dome their tops.
The U basses I've seen definitely had flat tops.
Neck angle depends on fingerboard thickness and bridge height, so I'd start from these plus your desired action at the 12th and then work out the angle from that. You might need a slight back angle, or be able to go flat, depending on your choices.
PostPosted: Mon Apr 04, 2016 2:34 pm
Last Name: Blower
City: Keighley
Country: UK
Cheers Chris,
So no fixed approach; that's good to know. I'll build it as I would a guitar and see how it goes.
Do people fit truss rod to ukes?
Regards
PostPosted: Tue Apr 05, 2016 4:35 am
Last Name: Reed
City: Stowmarket
State: Suffolk
Country: UK
Truss rods are practically unknown. Some fit carbon fibre reinforcement, most don't bother (but for a U Bass? Pretty low tension, so I wouldn't).
Rob Collins at Hebden Bridge (tinguitar.com) makes excellent ukes, so if you need supplies he's your local man.
PostPosted: Tue Apr 05, 2016 7:47 am
Last Name: Blower
City: Keighley
Country: UK
Thanks again Chris.
No truss rod then. Saves a bit of time and cost.
It never ceases to surprise me how many instrument makers there are locally. Never come across Rob Collins before, but good to know he's there.
I think I have everything now, I struggled to find tuning machines in th UK so I've ordered some from the US.
All the best
