It is currently Sun Jul 27, 2025 9:56 pm
PostPosted: Tue Dec 07, 2010 10:01 am
First name: Big
Last Name: Jim
When I wet sanded and buffed my latest effort on a Mando , I either wet sanded to deep or buffed to deep around the head stock on the sharp corners and exposed wood . SOOOO I guess I have to relacq. that area and try again .
What Tricks or sugestions do YOU have for keeping the headstock area from Sanding / Polishing to deep ?
[headinwall]
PostPosted: Tue Dec 07, 2010 3:08 pm
Stay away from the corners! ;)
PostPosted: Tue Dec 07, 2010 3:26 pm
First name: Todd
Last Name: Lunneborg
City: Andover
State: MN
Zip/Postal Code: 55304
Ignore them completely.
Todd Lunneborg
http://www.tlguitars.com/
http://www.fretboardjournal.com/
PostPosted: Tue Dec 07, 2010 3:33 pm
First name: Big
Last Name: Jim
Could it be that simple ?? laughing6-hehe So you wet sand the face and back of headstock and then just buff out ?
PostPosted: Tue Dec 07, 2010 6:57 pm
First name: Todd
City: Andover
State: MN
"Ignore them completely" is a mental trick. I wet sand my "top," not the "corner." I wet sand my "side" not the "corner." When I buff, I buff the top and stay off the edge, getting to say an 1/2- 1" inch away from the edge, "pert-near up-on," that way the feather of the buffer can buff the corner without me "trying" cuz I'm focused on the area that is 1/2 to an inch away.
Double pass your corners. If your spraying your top: I do a vertical pass across, across, across, across, across until the face is covered then I do a horizontal pass that splits the edge all the way around to "Frame it in." That way you "double your corner build" (each top coat is then the equivalent of 2 passes) so when it dries and you sand and buff there's that much more to help against burn throughs.
Todd Lunneborg
PostPosted: Wed Dec 08, 2010 9:51 am
First name: Big
Last Name: Jim
Ive been spraying my mandos that way [:Y:] And its only on the headstock where I have trouble. Of course Im fairly new at this so its more a matter of time than anything . Thanks for the insite . Thats what I like about this forum. [:Y:] [clap] [clap]
PostPosted: Fri Dec 10, 2010 7:49 pm
First name: Trevor
Last Name: Lewis
City: Crownsville
Zip/Postal Code: 21032
Another thing that helps is to not have sharp corners...! I round off my corners, even if just a little bit.
trev
http://www.PeakeGuitars.com
