It is currently Fri Jun 12, 2026 7:41 am
 Post subject: tenor string distance
PostPosted: Thu Jan 21, 2016 3:10 pm
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
What is a recommended 1st string distance from FB edge to string center?
I think I mad my neck too wide where it meets the body & so things are getting kind of far apart.
So I am considering bringing the 4th string out of parallel with the neck thus I bring them all a little closer????
idunno
Mike McNerney
PostPosted: Fri Jan 22, 2016 4:38 am
Last Name: Reed
City: Stowmarket
State: Suffolk
Zip/Postal Code: IP14 2EX
Country: UK
That would look odd to me. And anyway, I like the distance from fretboard edge to increase as I go up the neck because it makes playing easier (for me). Nylon strings are soft and easy to pull off the fretboard edge.
I'd centre the strings on the neck. Playability is more important than looks. I space at 9 to 9.5mm at the nut, 13mm at the bridge, but you should space them to suit your playing preferences.
Fortunately there is no "right" way to style a ukulele!
PostPosted: Fri Jan 22, 2016 1:02 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
I make mine 1/8" from the edge to the edge of the string at the nut. At the 12th fret its about 5/32
How wide is your nut? Most ukes are about 1-3/8" wide at the nut, and string spacing about 1-5/8" at the bridge Can you shave the neck down some?
PostPosted: Fri Jan 22, 2016 6:35 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
I use the stew -mac string fret calculator. I also use 1/8in from the nut to 1 and 4 th string
PostPosted: Mon Jan 25, 2016 5:10 pm
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
Thanks everyone. It looks like all my measure are better than I realized.
Bridges positioned, wholes drilled & ready to start finishing.
Mike McNerney
PostPosted: Mon Jan 25, 2016 10:34 pm
City: winnipeg
State: manitoba
Country: canada
I wish that I could move forward on a project that quickly.
Good luck.
Bob :ugeek:
