It is currently Fri Jun 12, 2026 9:22 am
PostPosted: Wed Mar 09, 2016 11:01 am
First uke.
I bought a couple of sets of friction keys. Neither has instructions nor can I find them on the Internet.
Grover standard model 2 appears to require a 3/16" hole with a countersink top. If that is correct, is it just a standard countersink? It seems that the cone will run awfully close to the outside diameter of the bushing.
Gotoh standard, which appears to require a larger hole to allow the force-fit of the knurled top bushing.
Advice on the actual installation method of these would be appreciated.
PostPosted: Wed Mar 09, 2016 12:58 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
You need a counter sink. Just drill for the bushing size. The bushing should press into the hole tightly or require a few taps with a hammer to get it seated. The shaft is smaller than the hole so it turns freely.
Stew Mac has dimension for their tuners. maybe yours is here too.... http://www.stewmac.com/Hardware_and_Par ... _Pegs.html
Looks like you want to drill a 5/16" hole
These users thanked the author Quine for the post: wbergman (Wed Mar 09, 2016 1:13 pm)
PostPosted: Wed Mar 09, 2016 1:13 pm
My Grovers are a different design, with a tapered bushing instead of knurled, but my Gotohs look a little like your photos.
