It is currently Wed Jun 18, 2025 6:41 am
Post new topic Reply to topic  [ 54 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sun May 29, 2011 1:09 pm
It turned out gorgeous, Robbie!!! [:Y:]
Thanks for sharing the build...I've really enjoyed following the photos and comments.
I would love to hear a sound clip... Eat Drink
PostPosted: Sun May 29, 2011 3:00 pm
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
Thank you Charlie!
This is by far my best sounding build.
I will see if I can get a sound clip together...
PostPosted: Sun Jun 03, 2012 8:58 am
First name: Neil
Last Name: Kwak
State: PA
I just wanted to bump this so that I could thank you for going so in-depth on neck carving and neck adjustment, Robbie. I'm about to start this in earnest on my first build and have been nervous since I haven't had a comprehensive resource to refer to. Now I do - right down to the barrel-bolt/MT neck joint! Thank you for documenting this!
BTW, I also see that a few of the steps I've taken this far I should have waited to do. It would have saved me a few headaches. Next time I'll know better. Thanks again!
Robbie_McD wrote:
Carving the heel:
First step is to lay out the centerlines and heelcap shape
Then the sides are ramped in a straight line, just shy of the layout lines
The cheeks are then carved
The Primary Facet is carved, which starts at a 45 degree angle to the centerline at the
heelcap. just shy of the layout line
The Secondary Facets have been carved, which take a tiny bit of material from the primary face to the centerline and just shy of the cheek line. I have already begun smoothing with my needle files
The carving is done, no big blowouts - ready for fitting!
PostPosted: Sun Jun 03, 2012 7:26 pm
First name: Rob
City: Cochrane
State: Alberta
Glad you found it useful, post pics when you get your build finished!
Rob
