It is currently Wed Jul 30, 2025 1:36 pm
PostPosted: Sat Jul 13, 2013 4:44 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
I think I have this guitar ready for French polishing. I have completed my pore fill, found any gaps and spot filled with CA and finally sprayed on a couple of thin coat of blond shellac to act as a sealer. I sprayed the sealer as I sanded the Z-poxy pore fill back to wood and the African blackwood really releases a lot of color.
An interesting note is that I cut the fret slots using an LMI template. The nut was cut as if it was a zero slot, and then cut through. Looking at an LMI serviced fret board, I noticed they had a note that said nut slot compensated for kerf width. Measuring I found that there nut position was .4 mm longer than mine. I had some black veneer that was .5 mm so I glued it to the end of the fret board with CA and lightly sanded it smooth. Now I can not measure a difference between my fret board and LMIs serviced fret board.
Here are some pictures.
PostPosted: Sat Jul 13, 2013 6:19 pm
John, That looks great. What if any plan is it and is that African Blackwood?
PostPosted: Sat Jul 13, 2013 6:50 pm
Last Name: Parchem
City: Seattle
State: Wa
Thanks! Yes it is African Blackwood with Australian Blackwood bindings.
It is close to the 37 Hauser plans drawn by Brume for the body, the top is braced as close I could come to Jeffrey Elliott's modification of the 43 Hauser plan he drew.
PostPosted: Sat Jul 13, 2013 7:49 pm
First name: D
Last Name: S
Beautiful John!
Looking forward to seeing it all shiny!
BTW, I like your website. My first build was one of those Saga LP's. Your build certainly looks nicer than mine.
I played mine a few times, threw it into the closet and started building from scratch.
Regards,
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Thu Aug 22, 2013 2:58 pm
Awesome!! That is a beautiful guitar :D African blackwood is the best :D
