It is currently Fri Sep 19, 2025 9:50 pm
 Post subject: Weird "relief" Science
PostPosted: Mon Jan 16, 2017 11:52 pm
I have a Taylor on the bench that when set for good relief at the 7-8 fret it has MORE relief around the 2-3! (Like twice as much)
I'm guessing it has taken a significant hit in the back of the peghead as there is a small fracture right near the weak spot, but no other visible signs of damage.
Could it be the fracture is not visible but goes inside the neck causing this?
Also, i shredded the neck block label trying to get it off. Do they sell replacements?
Thanks, Pat
 Post subject: Re: Weird
PostPosted: Tue Jan 17, 2017 12:42 am
Last Name: Cox
Is the nut action just way too high. Maybe somebody who liked to play electric style on their acoustic had the neck shimmed so the action was ridiculously low.... And then jacked up the nut to even it out.... You just never know....
PostPosted: Tue Jan 17, 2017 1:02 am
No, I cut the nut slots a few years ago.
And sorry, I forgot to mention that its only on the bass side. if you sight down the neck, the treble side looks totally normal and on the bass side you can see a dip right there around the 2/3 fret.
PostPosted: Tue Jan 17, 2017 1:05 am
I have worked on several Taylors that have uneven relief from treble to bass.
PostPosted: Tue Jan 17, 2017 2:03 am
I've seen it too Chris, but for reference, I have worked on this guitar and it was normal before the apparent impact.
PostPosted: Tue Jan 17, 2017 6:05 am
Last Name: Farmer
City: Durango
State: CO
Is it a bulge at that mark? I've seen a few t-rods split the neck there.
PostPosted: Tue Jan 17, 2017 7:56 am
No, its flat. At first I thought that was the impact spot, but I realized there are no indentations there.
PostPosted: Tue Jan 17, 2017 9:20 am
Last Name: Farmer
City: Durango
State: CO
hmmm.
Loose fingerboard end?
Taylor sends out sheets of neck labels. I'm not sure if you have to be a warranty center though. Maybe there is one near you. I'd be supersized if they wouldn't spot you one.
PostPosted: Tue Jan 17, 2017 2:49 pm
I set-up a Taylor with a neck like this this morning..... Some will, some won't, so what...... next.....;)
Regarding the label naphtha applied with an eyedropper under a lifted corner (you may need to get a nail under there to lift it). Let the naphtha soak it's way down the label as you gently pull it off. Then place it on waxed paper to keep it flat and not adulterate the remaining adhesive. They usually can go right back on with no additional adhesive. I use a violin post setting tool to position the label so I can see if it's crooked or not before reaching in and pressing it back fully in place. A dowel with masking tape can do the same thing.
One last thing. Clamp the neck in a leg vice or something suitable sideways. While flexing the headstock back and forth and twisting it too look for separations of the fret board. Sometimes these separate and can throw off the neck fret plane and the separation needs to be stressed to find it.
I just reglued a Les Paul Standard that this happened to an hour ago. We had to flex things to find the separation.
These users thanked the author Hesh for the post: Pmaj7 (Tue Jan 17, 2017 3:49 pm)
PostPosted: Tue Jan 17, 2017 4:09 pm
Last Name: Farmer
City: Durango
State: CO
I'll have to post a video of my proprietary vacuum label placing system. :) (hint: just stick it on the end of what ever vac tubing you use!)
It answers the question," how many luthiers does it take to place a Taylor label"
Answer: one and a $1000 vac system. ;)
