It is currently Fri Sep 19, 2025 1:52 pm
 Post subject: Neck repair jig needed
PostPosted: Wed Oct 05, 2016 1:00 pm
First name: Bo
Last Name: Toepfer
City: Prince Frederick
State: Maryland
Zip/Postal Code: 20678
Hi, I have an older Yamaha Acoustic, that suffered a fall and snapped the head stock off of the neck. I am looking to make a jig , and a suggestion for the glue of choice for this repair
Thanks in advance , Bo
PostPosted: Wed Oct 05, 2016 4:07 pm
Last Name: Farmer
City: Durango
State: CO
A picture or two of the break would make advice easier.
PostPosted: Wed Oct 05, 2016 9:15 pm
First name: Allan
Last Name: Bacon
I'm a novice, but this has worked for me on 8 or 10 guitars. I made a simple jig that clamps to the neck and has a vertical piece that keeps the headstock from sliding out under clamp pressure. Now, this works as long as there is enough striation in the grain to positively locate the headstock. If not, I have another jig that is a little more elaborate that positively locates the pieces. There is a caul that covers the neck for clamping to the fret board, and one that is used for the clamps over the headstock tang. These are early pics, and I've since added lines to help with the alignment. I also use a caul that clamps to the vertical to assure there is no upward movement. Titebond I is your friend. If you don't get a good alignment you can use heat to separate it and try again. I'll just post the pics and if you have questions you can ask after you've seen them.
PostPosted: Wed Oct 12, 2016 2:25 am
On the main forum I was looking at a similar subject -
https://www.youtube.com/watch?v=D6lzTM__Yrs
