It is currently Sun Apr 26, 2026 11:03 am
PostPosted: Fri Sep 01, 2017 1:33 pm
First name: Daniel
Last Name: Petrzelka
State: Washington
I'm new to neck resets, and have a couple no-name parlors that need some attention.
There is the tried a true method of injecting steam into the dovetail via a pneumatic needle and steam generator of some type (espresso milk steamer). This is a proven approach, but also has some risks ( hazing from steam)
I have also started to find some very limited information about using non-steam heat sources via heating cartridges or what appear to be a long tipped temperature controlled soldering iron (I believe Dan Erlewine shared at the ASIA conference based on images I've seen)
https://www.instagram.com/p/BVPfnYtlplo/?taken-by=martinluthierking
https://www.instagram.com/p/BVLMRDllmQr/?taken-by=martinluthierking
https://www.instagram.com/p/BXGOQPolwzk/?taken-by=martinluthierking
http://www.luthing.com/steamless-neck-re-set-ian-davlin/
Are any of you using a cartridge heater or know more about the approach with a long tipped temperature controlled soldering iron?
PostPosted: Tue Sep 05, 2017 12:25 pm
Last Name: Cox
There are many many reasons that the conventional/traditional method is such as it is.....
1. Steam gets into nooks and crannies..
2. Steam works across gaps and turns corners to heat stuff that's not touching....
3. Steam transmits a tremendous amount of energy relatively quickly
4. Often a little moisture makes the glues loosen up better
Etc.
The one downside is the humidity can raise the grain and possibly warp stuff. I hear this frequently raised as a theoretical "issue" - but it doesn't seem to be an actual real life problem for 99% of neck resets done with steam...
Perhaps I am wrong.. But this kinda feels like doing a lot of work to fix stuff thats not really a problem except in perhaps a very small number of cases....
On the old parlors... Often these have slipped the dovetail and there is a gap at the heel/body joint. These hardly take more than a puff of steam to loosen and release the joint. Not a major risk to finish or other glue joints....
These users thanked the author truckjohn for the post: dpetrzelka (Wed Sep 06, 2017 9:28 am)
PostPosted: Tue Sep 05, 2017 12:37 pm
First name: Daniel
State: Washington
Thank you John - makes sense for me to work within the traditional method.
PostPosted: Tue Sep 05, 2017 1:16 pm
This was just demonstrated at Northwoods two weeks ago. From what I'm told being Cinderella here who didn't go... people thought it was pretty cool.
These users thanked the author Hesh for the post: dpetrzelka (Wed Sep 06, 2017 9:11 am)
PostPosted: Wed Sep 06, 2017 9:05 am
I think that's pretty cool and perhaps just needs more trials to see how good it is. Steam does work great obviously but I've definitely had more than one occasion where some finish work was necessary due to steam leaking out and ghosting the finish.
These users thanked the author jfmckenna for the post: dpetrzelka (Wed Sep 06, 2017 9:11 am)
PostPosted: Wed Sep 06, 2017 9:15 am
First name: Daniel
State: Washington
If I can track down more information on what tip they are using on the soldering station, or what small cartridge heaters people have been using I'd love to give it a try.
Yet another reason I should have found a way to go to the Northwoods Seminar...
PostPosted: Wed Sep 06, 2017 10:25 am
Again from what the folks I know can remember through the fog....;) of Northwoods it was cartridge heaters and even though they are inexpensive it did ruin them at times.
Another opinion shared with me from someone who I absolutely respect this method was described as a "solution searching for a problem..."
Or, in other words blushing commonly happens with steam or conventional neck removal and just as commonly we fix it and make it go away. No biggie, it's been done this way for half a century or more.
It's also possible at times, not always to remove a neck with minimal if no blushing at all. It just depends on how much glue someone back in time poured into the dovetail.... and/or slathered it on the cheeks.....
In the business some vintages of certain brands are known to be more resettable than others in terms of being problematic or not. In addition some vintages of lacquer for some brands are also know to be more forgiving or totally suck making it impossible to get a neck off without having to do a goodly amount of finish touch-up. Even the heel design of certain brands (Guild) can dictate how much time you are going to be spending fixing mistakes.....
Luthiers with this level of experience, and Dave Collins has this experience know which ones will cooperate and which ones to kick the can down the road if possible or employ the ole "punitive quotation" to persuade someone to go elsewhere.
My impression is that the dry heat method does not guarantee that you won't have finish touch-up to do. Stuff happens, and again taking into account what I shared about some eras of instruments from some makers being a nightmare to reset it's likely that this method will not guarantee that any reset will be without the need for finish touch-up or the heel will break in half, etc.
You know too these things that some folks develop a block of sorts to thinking that it will suck for them are not always anything to be afraid of. Fretting the guitar on a newly built and finished guitar with the neck on the instrument is one that many here have expressed real fear of doing. Touching up the finish after a neck reset is not hard, takes little time beyond waiting for the finish to cure and if learned properly from someone who knows what they are doing it's nothing to be fearful of.
This lends some Creedence to the idea that this is a solution searching for a problem. Besides the steam pot and probe is great to raise the RH in your shop in a Michigan winter.
These users thanked the author Hesh for the post (total 2): Clinchriver (Wed Sep 06, 2017 7:09 pm) • dpetrzelka (Wed Sep 06, 2017 10:32 am)
