It is currently Sat May 02, 2026 11:16 am
PostPosted: Wed Jul 08, 2020 12:43 pm
First name: Conor
Last Name: Searl
City: Duncan
State: British Columbia
Zip/Postal Code: V9L 2E5
This guitar has many missing sections of binding along the neck, and what is still there is coming loose.
The obvious solution seems to be to remove all of the binding and redo it. This doesn't seem too challenging, but I've never done any binding work. Is there something I'm missing or should know?
PostPosted: Wed Jul 08, 2020 4:00 pm
Last Name: Reed
City: Stowmarket
State: Suffolk
Zip/Postal Code: IP14 2EX
Country: UK
I think it's just a matter of replacing the binding.
The frets look as if they don't overlap the binding, which makes it easier.
The hard part will be making the height of the binding match the fretboard. On a new build you'd just scrape it down to that level. But the frets are in the way of that!
My guess about how I'd do it (and this is just a guess) is that I'd glue on the binding, scrape it down between the frets, and then carefully remove the high spots at the fret ends with a chisel. It would take ages and probably not look perfect but good enough.
I think a professional would remove the frets, replace the binding, and then re-fret. Which I'd do if I thought I could re-fret it as well as the current fretwork.
These users thanked the author profchris for the post: Conor_Searl (Thu Jul 09, 2020 12:25 pm)
PostPosted: Wed Jul 08, 2020 4:26 pm
First name: Freeman
Last Name: Keller
I'm not a professional but I would pull the frets, replace the binding, scrape and sand it level and fret over it. If you use CA for the binding you can pretty well keep it out of the fret slots, otherwise get some of the little teflon spacers. You are going to have issues with finish but you would if you tried to just replace the missing pieces.
I bind my fretboards before they go on the neck so I have much better access to the entire board for clamping and gluing but I think if you are creative you can work around the body.
PostPosted: Sat Jul 11, 2020 11:04 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
I think (mixing my metaphors here) fixing a flat tire on a Chevrolet takes as much effort as fixing a flat on a Cadillac. So it is, too, with guitar repairs. I hope OP holds that thought.
Peter Havriluk
PostPosted: Tue Jul 14, 2020 11:40 am
First name: Conor
Last Name: Searl
City: Duncan
I assume you mean some jobs are simply what they are regardless of the quality of the instrument, and the quality of the instrument doesn't dictate how those jobs are done, only whether or not a customer thinks its worth doing. Am I right?
