It is currently Sat Jun 13, 2026 5:43 am
PostPosted: Thu Oct 23, 2025 3:33 am
Suzuki 12 string, early 1970s, headstock and heel broken by an errant ball at a rugby match.
Repaired by a friend of her father at the time.
Nut and bolt in the headstock, nut under the truss rod cover, bolt head under filler, heel break at glue line secured by large wood screw down through the truss rod (!) and a smidgin of glue that was actually holding the crack apart, causing a ski ramp at the body joint.
Neck was a dowelled joint.
The repairer told her not to put 12 strings on it, just use it as a 6 string, about 20 years ago...
These users thanked the author Colin North for the post: SteveSmith (Fri Oct 24, 2025 4:24 am)
PostPosted: Thu Oct 23, 2025 12:27 pm
Here's an Aria that someone gave me about 20 years ago. It would need a new top and neck but I've kept it around because I think the box is BRW. Surprisingly the fix has held and the guitar still has string tension on it idunno
These users thanked the author SteveSmith for the post: Colin North (Fri Oct 24, 2025 3:57 am)
PostPosted: Fri Oct 24, 2025 4:01 am
That's a really pretty back set.
These users thanked the author Colin North for the post (total 2): gxs (Fri Nov 21, 2025 5:48 pm) • SteveSmith (Fri Oct 24, 2025 4:25 am)
PostPosted: Fri Oct 24, 2025 5:38 am
It would take a lot of work to save it but I’ll probably do it. Just too nice to throw away.
Look forward to seeing how your repair comes out.
PostPosted: Sat Oct 25, 2025 5:40 pm
Last Name: Russell
State: Michigan USA
ARRG.... Those are some ugly repairs, clearly someone had no clue how to deal with them.
Colin, That looks like it "was" a nice guitar at one time. Are you fixing that or just showing what a really bad repair looks like?
Steve, I think if I had that guitar I would carefully remove the back and sides and build another guitar with them. That is a beautiful set that would look great on a new guitar.
Cheers,
Bob
These users thanked the author RusRob for the post: SteveSmith (Sat Oct 25, 2025 7:37 pm)
