It is currently Wed May 13, 2026 12:06 am
PostPosted: Mon Apr 04, 2005 5:55 pm
For those few who have used this , what material would you suggest using to remove the finish at the bridge and FB extension? TIA
PostPosted: Tue Apr 05, 2005 4:01 am
Scribe. scrape and sand. I would never use a chemical remover because of creep, contamination and possible staining and may even weaken the top if it infiltrats the top.
PostPosted: Tue Apr 05, 2005 4:04 am
JJ I turn a hook on a single edge razor blade. Makes a nice littl cabinet scraper. You can even grind away on both side to make it narrower. Works great.
PostPosted: Tue Apr 05, 2005 4:14 am
Like the Zootmans said!! I use a box knife razor blade and a single edge shaving razor blade. the box knife razor blade is too stiff to bend, but I find it nice for getting right up aganst the scribe line and corners.
Users browsing this forum: No registered users and 39 guests
