It is currently Fri May 15, 2026 10:53 am
PostPosted: Fri Jan 05, 2007 12:09 am
Last Name: Johnson
State: CO.
Zip/Postal Code: 80224
I have a back, joined and thickness sanded and noticed a crack, running with the grain extending from bottom up about 7". I know with other woods, 'flooding' the crack w/ca seems the approved remedy. However, since Coco is so oily, will the C/A glue and hold?
PS re Coco; a little amount of sanding dust got on my arm and itching right away! Washed w/ soap and cold water and itching subsided.
How do you guys work with this nasty and beautiful wood?bob J39087.3416435185
PostPosted: Fri Jan 05, 2007 12:55 am
i wear a painter balaclava, mask, safety goggles,
tyvek coverals, and inspection gloves when sanding it. must be quite a sight, though i've never looked at myself in the mirror. i have the dust collector, the air cleaner and a box fan with filters running. afterwards i vacuum and blow the room out using the compressor.
when handling it i usually where the gloves until i get it wiped down and am confident that all, or as close to all as practically possible, the dust is gone.
from what i have read the sensitivity gets worse with continued exposure. some can't or won't work with it at all as a result.crazymanmichael39087.5188888889
PostPosted: Fri Jan 05, 2007 1:52 am
It will irritate my sinuses but I don't get skin rashes or respiratory reactions like some. Not every one is sensitive to it.
PostPosted: Fri Jan 05, 2007 2:31 am
Bob CA will work just fine. Luckily no sensitivity here.
PostPosted: Fri Jan 05, 2007 3:07 am
I just had the same thing on some Coco happen to me. I used CA glue with no adverse effects. I am not sensitive to the Coco now but I hear that the sensitivity can develop over time. I am very careful with using this wood.
Homeboy
PostPosted: Fri Jan 05, 2007 5:44 am
if it's irritating your sinuses, Michael, you are not wearing adequate respiratory protection.
Yes, CA will glue cocobolo.
PostPosted: Fri Jan 05, 2007 6:30 am
[QUOTE=Howard Klepper] if it's irritating your sinuses, Michael, you are not wearing adequate respiratory protection.
Yes, CA will glue cocobolo.[/QUOTE]
Yes I do wear a respirator when sanding and carving, and have no issues. But have be guilty of taking off the respirator and blowing away some dust by mouth every now an then
PostPosted: Fri Jan 05, 2007 8:36 pm
Last Name: Johnson
State: CO.
Thanks Guys,
Perhaps anyone ho builds with Coco for another should receive additional hazard duty pay .
Are there any other woods that are as 'oily' as Coco?bob J39088.3706134259
PostPosted: Sat Jan 06, 2007 2:01 am
Bob...I had Bolivian Rosewood (Pau Ferro) kick my butt many years ago. Once the rash broke out it was about 3 days later that it looked like I was rolling in poison ivy and ready for serious medical help. I had no idea wood could cause such problems. I will say, at that time, that I didn't have a dust collect and it usually would be covered in dust for hours at a time without thinking it was a problem. I think with a little caution it all can be avoided (for most people).
Brad
Avon, OH
PostPosted: Sat Jan 06, 2007 2:09 am
First name: stan
Last Name: thomison
City: branson
State: mo
Zip/Postal Code: 65616
Country: united states
Bob the CA will work well. If have any concern about it, you can wash it a little with acetone. If the join was sucessful, the crack no problem. I never have used anything on coco to retard the oil's and never a problem with join or crack fixes and I have built more with it than any other wood.
