It is currently Tue Jul 29, 2025 3:36 am
PostPosted: Tue Mar 18, 2008 3:44 pm
I just finished making the wheat motif stips from John Bogdanovich's book "Classical Guitar Making: A Modern Approach to a Traditional Design".
I'm really pleased with his book it gives excellent step by step instructions. I used macasser ebony and basswood for the white lines. The wheat lines are only .01" in width. These turned out to be easy to produce from hand planing slices of basswood. What I like about this wheat motif it is almost exactly like the wheat design shown on the Torres guitar pictured in Roy Courtnall's book.
Now all I have to do is bend it for a rosette.
PostPosted: Tue Mar 18, 2008 3:50 pm
Marc,
I have admired the "wheat" from Bogdanovich's book as well and plan some day to make some. You did a beautiful job and given me encouragement.
Great work,
Max
Max Bishop
Brighton, Michigan
PostPosted: Tue Mar 18, 2008 3:55 pm
Thanks Max, I had fun making it. It took a little longer than I thought but I think I could get through it much quicker now that I know the steps.
PostPosted: Tue Mar 18, 2008 3:59 pm
First name: David
Last Name: LaPlante
Nicely done Marc!
I bend mine using a banding iron heating through a moist cloth.
PostPosted: Tue Mar 18, 2008 4:00 pm
I was going to make the wheat too, but ended up using only half as a rope type motif, because my white/maple was too thick and it looked funny as wheat, and would have had to be way too wide for what I wanted to do. It was my error though. The book does do a nice job of telling you how to do it.
PostPosted: Tue Mar 18, 2008 4:01 pm
Thanks David, that's exactly the way I'll try to bend it.
PostPosted: Tue Mar 18, 2008 4:02 pm
Last Name: Beaver
City: Lake Forest
Very well done! Love to see the finished rosette/guitar.
Joe Beaver
Maker of Sawdust
PostPosted: Tue Mar 18, 2008 4:07 pm
WaddyT wrote:
I was going to make the wheat too, but ended up using only half as a rope type motif, because my white/maple was too thick .....
I wrote J. Bogdanovich an email asking for a source of the thin white, he noted that lmi sells sheets or you could just use shavings from planing. I was amazed at how accurate and consistent the shavings were in thickness. All I had to do was soak them in water to get them uncurled, then stretch them out to dry. Gives near perfect .01" veneer at essentially no cost.
PostPosted: Tue Mar 18, 2008 4:09 pm
Bob C at RC Tonewoods also has the "off white" .010 fiber sheets.
PostPosted: Tue Mar 18, 2008 4:21 pm
Thanks Waddy, however I was looking for a solid wood rather than wood fiber. Maple is too brittle to get shavings that thin but I found that basswood planes very easy and gives long continuous strips.
I think the white under 'colored veneers' at lmi is solid wood, but it's not inexpensive.
PostPosted: Tue Mar 18, 2008 4:28 pm
It is my understanding that you can get nice shavings like that from Dogwood or Boxwood.
PostPosted: Tue Mar 18, 2008 4:41 pm
Thanks again Waddy, if I find some I'll give it a try.
PostPosted: Tue Mar 18, 2008 5:13 pm
Country: Romania
I think that maple would plane better too if you would soak it a bit before each plane pass. Thats how I get nice cypress shavings. Dry, they are cracked every 2-3mm !
Build log
PostPosted: Tue Mar 18, 2008 5:21 pm
Very Cool Marc
Could you possibly give a little tutorial on how you do this?
PostPosted: Tue Mar 18, 2008 6:29 pm
Joe, Thanks when I finish the rosette I'll post a picture.
Alex, I tried with wet maple, just didn't have much luck. Basswood worked great.
John, Thanks, I wouldn't feel right about a tutorial because it would be exactly what is in J. Bogdanovich's book. I followed the steps in the book very closely. For me the explanation of the wheat alone was worth the price of the book.
PostPosted: Tue Mar 18, 2008 9:47 pm
That book is a bargain at it's price. I think you can get it in the $18 - 20 range.
PostPosted: Wed Mar 19, 2008 9:07 am
First name: David
Last Name: LaPlante
I don't have a photo sequence for this but here is a shot of my initial glue up for the wheat (or herringbone if you will) marquetry.
From this point, slices are cut, assembled end to end and and laminated to the central white "spine" veneer then stripped out.
Users browsing this forum: Bing [Bot] and 6 guests
