It is currently Fri Jul 25, 2025 12:02 am
PostPosted: Sun Aug 17, 2008 9:21 am
I getting ready to finish a bass I have been working on and would like some help with finish type and schedule. The bass is a maple neck through design design with a figured maple top and an ash back. I would like to finish the bass with a translucent finish. It has been many years since I have messed with any finishes but based on my limited experience I have a few guidelines I will be starting with. I would prefer to use a waterbased finish since I don't like to dealing with chemicals (VOC's, etc). I would also prefer somethings that is more workable like Nitro. (ie layer coats together, rub out, rework, etc) I would also prefer something that cures quickly (days not weeks). So with this being said...what grain filler, what sealer, what finish, how many coats, cure time, etc....
Thanks!
Brad
Avon, OH
PostPosted: Sun Aug 17, 2008 9:22 am
City: Keene
Tung oil or True-oil are both awesome on basses...
PostPosted: Sun Aug 17, 2008 9:28 am
True-oil? Tell me more.....
Any pictures of either finish? How many coats? How do you deal with wood like ash (open pores) with an oil finish.
Brad
Avon, OH
PostPosted: Mon Aug 18, 2008 11:28 am
First name: Stephen
Last Name: Ziegenfuss
City: Jackson
Hey man,
I have not yet tried the hand-rubbed oil finishes or french polish, but they do look good to me...If you remember when we were at Hesh's place looking at his guitars, I know he has hand rubbed at least one and you would be hard pressed to pick it out from the crowd...
I have tried some other finishes, and have settled in on a low VOC automotive poly...It is not as bad as nitro, and it dries to sand and buff in 8-16 hours (obviously, it takes a great deal longer to completely finish, but it will not mark like nitro early in its life). It looks really good...(and I spray it out of a preval unit)
Stephen
www.ziegenfussguitars.com
PostPosted: Mon Aug 18, 2008 12:45 pm
Cures days not weeks? Well waterborne acrylic lacquer can be rubbed out in 7-10 days if curing conditions are right. French polish is a process where you both build and rub out as you go tru-oil needs some cure time but not as much as waterborne depending on application process. So you have several options but understand each has a distinct film appearance and attributes. don't expect nitro harness from a quick cure product. That is not to say inferior hardness just different type of hardness. Nitro is hard but has little elasticity as compared to French polished shellac or a true-oil finish. So you should play with a couple of the quick cure finish and see what best suites you.
