It is currently Tue Jun 02, 2026 11:26 pm
 Post subject: Binding "Slitter"
PostPosted: Thu Oct 09, 2008 2:00 pm
I'm so tickled every time I use this at how well it works, I thought I'd share it.
I basically wanted a way the size bindings (to width) accurately, consistantly, safely and without loss via kerf. The jig I came up with is easy to make & use.
The components are a hardwood block glued to ply ("the bed") and clamped to a bench, a "free" block, a #2 X-ACTO blade, shims & clamps.
You hold the binding against the bed block and slide shims of equal thickness up to it.
Then put the free block over the shims & binding. It will hold down the binding & its left face establishes the location for the slit.
Clamp the blade to the free block so it just touches the binding.
Pull the binding out & check the blade scratch for proper location (& move free block if needed). Then, feeding from the back, the sequence is simple
PULL THROUGH
FLIP END FOR END (to keep scores vertically alligned - THE KEY!)
PULL THROUGH (scoring the opposite side)
restart the binding & TAP THE BLADE (for a little more depth of score)
REPEAT
At some point, the scores will meet in the middle & the binding will seperate.
You can do a 3-pc slit by doing the above BUT the rotate 180 deg SIDEWAYS and repeat BEFORE tapping the blade (ie 2 pairs of scores)
The jig works for solid or laminated ABS and for wood (although wood takes more "taps"). This is .300" wide curly maple slit to .200" & .100"
Milton, ON
These users thanked the author Dave Stewart for the post (total 2): Colin North (Thu Jul 25, 2019 6:02 pm) • Kevin Mason (Sat Sep 27, 2014 9:48 am)
 Post subject: Re: Binding "Slitter"
PostPosted: Fri Oct 31, 2008 9:13 pm
Thanks Dave. I like it. I'll be using it for sure.
PostPosted: Sat Nov 01, 2008 8:50 am
Very clever Dave and great pics and step-by-step too! [:Y:] [clap] [clap] [clap] [clap] [clap]
PostPosted: Mon Nov 03, 2008 9:04 pm
Brilliantly simple and timely. I was wrestling with this task last night and messed up a binding. Heading down to the cellar 5am tomorrow morning armed with this idea - thanks for sharing it.
PostPosted: Sat Nov 08, 2008 9:45 pm
really cool. i am totally into the simple jigs. big jigs are nice, but i prefer the simplicity and closeness of working things by hand and with simple jigs like this.
thanks
PostPosted: Fri Feb 13, 2009 6:38 pm
Thanks to you Dave, I was able to make myself a nice binding strip yesterday.
Cheers & thanks Hip.
PostPosted: Thu Feb 19, 2009 5:54 pm
Very nice. Thanks for putting the pictures up for everyone to see.
Chuck
PostPosted: Mon Apr 13, 2009 3:23 am
First name: Daniel
Last Name: Green
City: Milford
State: Ohio
Zip/Postal Code: 45150
Country: U.S of A
Thank you very much for sharing, I look forward to learning here at OLF
