It is currently Wed Jun 10, 2026 8:41 am
 Post subject: Misc. lacquer question
PostPosted: Wed Sep 08, 2010 2:52 pm
I'll be spraying lacquer for the first time coming up here in the next few weeks. How do you typically clean the gun AFTER spraying a coat? With poly I needed to spray MEKP immediately following each coat, and I could only mix enough finish for the coat at hand since it solidified immediately after spraying. I'm wondering if I can put thinner in one cup, a day's worth (3 coats) of lacquer in another, and just interchange them, spraying the thinner after each coat of lacquer and only filling the lacquer cup once a day?
PostPosted: Wed Sep 08, 2010 3:27 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I've left lacquer (assuming you're talking nitrocellouse lacquer) in my gun for several days. No need to clean between coats. The solvent disolves the finish in the gun.
PostPosted: Wed Sep 08, 2010 3:33 pm
I usually spray my 3 coats in one day then clean the gun with lacquer thinner so it will be clean for the next day. I've never tried leaveing it in the gun for more than a day, but that might work as well.
PostPosted: Wed Sep 08, 2010 4:23 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
Lacquer is very forgiving in the gun, I leave the gun between coats as Mark says, but I close the needle. I have left it overnight without any problems. I give the gun a good cleaning after I am done, this requires taking it apart to clean not just blowing some thinners through it. Use some high grade gun lube to oil the needle so it won't stick to the packing. The 1st spray on the next use will get rid of the lube if it is in the fluid transfer areas.
Fred
Fred Tellier
PostPosted: Wed Sep 08, 2010 4:24 pm
Lacquer can be left in the gun for a while. My guns finish is not harmed by lacquer solvents. As for the spray schedule I shoot 8 coats on the first day , one hour apart. Let set 3 weeks then level sand. Lacquer is as much about technique and prep . You want to have about a .016 to .020 build. then level sand back and a few coats of finish spray to buffing and polishing.
PostPosted: Wed Sep 08, 2010 5:26 pm
Thanks, guys! It sounds much more forgiving. Poly wasn't hard to spray or mix, but it was time consuming for the one run guitar maker and difficult to buff. I'm really looking forward to putting the mask on and learning about lacquer. Especially since it seems so easy to use.
Thanks for the tips on your schedule, John. I haven't heard of anyone doing 8 in a row before, but it sure seems convenient. I was planning on 3 coats, 3 coats, level and repeat again. I'll need to do more research. Yours is the most appealing!
PostPosted: Wed Sep 08, 2010 6:19 pm
I use CF Martins finish schedule . It works for me
PostPosted: Wed Sep 08, 2010 7:09 pm
I think I'm going to go with it. Thanks, John. Do you thin the lacquer?
PostPosted: Wed Sep 08, 2010 7:29 pm
Last Name: Smith
City: Graton
Zip/Postal Code: 95444
If I leave my guy for most of the day I soak a small piece of rag with thinner and put it on the end of the gun then rubberband a piece of plastic over it. It might not be all that necessary with laquer but can be used with oil, or water based finishes to good end. Good luck on your first shot. With my rig I found I had to get a slower thinner. This made all the difference.
http://goatrockukulele.com
PostPosted: Wed Sep 08, 2010 7:43 pm
I always shoot thinner for a few seconds after spraying a coat.
PostPosted: Thu Sep 09, 2010 12:50 am
I'm going to go ahead and do that. I have the 3M PPS system, so snapping in a cup with thinner only takes a moment.
PostPosted: Thu Sep 09, 2010 9:13 am
First name: Mark
Last Name: Morris
City: Sedona
State: AZ
Zip/Postal Code: 86339
James the 3m PPS looks interesting, have you had it long and why that system?
PostPosted: Thu Sep 09, 2010 10:36 am
First name: Chuck
Last Name: Gilbert
I'm with Howard - a 10 second burst of thinner through the gun after each coat. A full cleaning after the last coat of lacquer. I also learned to pour anything I put into the gun through a fine mesh strainer. That solved a couple of issues I had early in my (ongoing) learning process.
Good luck.
Chuck
"To live a creative life, we must lose our fear of being wrong"
- Joseph Chilton Pearce
PostPosted: Thu Sep 09, 2010 2:57 pm
First name: Nelson
Last Name: Palen
I've left clear nitro in a gun for months and go right back to spraying.
I don't recommend it however just for the principle of it. :D
Speaking of straining, what do you guys use for straining aniline dye after dissolving in thinner or alcohol?
I use cloth (couple layers) rather than a fine mesh strainer but it's messy because the cloth absorbs a lot of the solution.
Is there a super fine strainer somewhere out there?
Nelson
PostPosted: Thu Sep 09, 2010 2:59 pm
I've used it once to date, and I bought it at Rick Turner's recommendation. It makes clean up and mixing so easy.
PostPosted: Thu Sep 09, 2010 8:49 pm
James,
Lacquer is a great finish. You can leave it in your gun overnight, but not beyond that. It will clog your gun if you do.not clean it right away. Lacquer melts into the previous coat, so the coats do not stack up like enamel or some other finishes. But the thicker you make it, the nicer it will look. Many luthiers will put 8 or 10 or even more coats on the guitar. Spray, and wait. Spray and wait. Then buff. Buffing is the most sensitive part of the process. You can burn through the finish in a second. Be very careful when buffing. Use lacquer thinner to clean your gun. If you ever get the opportunity, take a class on using lacquer. It will pay off. I use nothing but nitrocellulose lacquer on everything I build. Furniture included. It will outlast anything on the market. Martin uses it.
PostPosted: Thu Sep 09, 2010 11:17 pm
Todd, how do you measure build thickness?
PostPosted: Fri Sep 10, 2010 7:18 am
First name: Damon
Last Name: Wack
State: FL
On my last guitar I tried 6 coats on the top, nine on the back, and twelve on the sides. It turned out very well, and the top coat was nice and thin, about 4 mil. Best sounding one to date, but it was only #4, so I am no expert - though I have a lot of spraying experience on other things. I have a true HVLP system I bought for spraying an aircraft I was building, and I like to thin about 50:50. I pull the nozzle and needle and clean them if I leave lacquer in overnight. To measure the thickness I use a micrometer, some of the lacquer flakes off the tape when I pull it off the bridge or fretboard area.
Damon Wack
https://www.facebook.com/LindamonGuitars
PostPosted: Fri Sep 10, 2010 9:18 am
James, I spray on glass panels (4"x6") with a paint stick taped to one side to hold. I use a razor blade to peel off the film for measuring. There are also wet mil gauges available from good paint stores that are the size of a biz card with graduating sides for measuring the wet film. I am not really concerned with the wet film so the glass cards offer a way to give the dry film a closer look. Might be handy to have several cards and spray them with different reductions and gun settings to get the film build per coat that you are after.
jw ( o)===:::
PostPosted: Fri Sep 10, 2010 3:12 pm
With the acetate covers I use inside f-holes, held in place with a balloon, finish flakes off easily after removal..... shows actual deposition, easily measured.
Milton, ON
Users browsing this forum: Michaeldc and 22 guests
