It is currently Sat Jun 21, 2025 11:13 am
PostPosted: Thu Oct 14, 2010 8:02 pm
I've drawn an arm contour using sweep 2 rails. The cross section curves are tangent to the body face but the surface bulges slightly and is not tangent to the body face. Rhino help has been no help at all. Any thoughts on how to force one surface to be tangent with another?
PostPosted: Thu Oct 14, 2010 9:19 pm
Sheldon can you zip the file and attach it here, or do a couple of screen shots so we can see?
PostPosted: Thu Oct 14, 2010 10:12 pm
First name: Trevor
Last Name: Lewis
City: Crownsville
Zip/Postal Code: 21032
Hey Sheldon, you should be able to use the network surface command with the same inputs you would use for the 2 rail sweep. Be sure to select the edges of the faces that you want the new surface to be tangent to, and not just the curves that are at those edges. Another command you might want to play with is the Blend Surface command...this lets you fill the gap between two separated surfaces with a surface that is tangent to both.
Post some pics or the file & I'm sure we can help you a bit more...!
Trev
http://www.PeakeGuitars.com
PostPosted: Fri Oct 15, 2010 1:06 pm
Trev
Bingo! Trev you ROCK!
PostPosted: Sat Oct 16, 2010 8:08 pm
First name: Trevor
Last Name: Lewis
City: Crownsville
cool - I'm glad it worked! Let me know if you run into anything else
(c:
Trev
cron
