It is currently Sun Jun 22, 2025 9:23 pm
PostPosted: Thu Sep 29, 2011 12:45 am
First name: David
Last Name: Malicky
Zip/Postal Code: 92111
Transferred from the Tap Tuning thread, here's a new thread on the topic of stiffness, strength, and creep in guitar tops. Hopefully that thread will be helped by fewer topics in it.
The main prior posts (from viewtopic.php?f=10101&t=33563&start=50)...
david82282 wrote:
On minimal strength, also keep in mind the distinctions between stiffness, strength, and creep. E.g., a rubber band is fairly strong but not stiff; a glass rod is stiff but not strong; silly putty and warm plastic creep. Acoustics are governed by stiffness (and mass) distributions. We don't often see braces breaking, so strength per se is not a major problem for guitars, but long-term creep is. Creep is most likely in wood fibers that are under high stress -- stress that isn't high enough to break the brace, but is enough to deform it over time. Shaving a brace reduces its stiffness, of course, but its relative vulnerability to creep also depends on its shaved cross-section (rectangular, triangular, parabolic...). For a given amount of stiffness, a triangular cross-section has relatively high stress and is thus more prone to creep than a rectangular one (though the triangle also has slightly less mass). The brace pattern matters, too... e.g., Falcate bracing has 4 rectangular braces passing longitudinally under the bridge, which should give it relatively low stress and creep. I can start a new thread for this topic if wanted.
Trevor Gore wrote:
Yes, that's correct. It also has carbon fibre on top of the braces to further guard against cold creep.
Here's some more stuff that people may find contentious beehive : It is very, very, very difficult to make a really responsive steel string guitar that doesn't incorporate carbon fibre in the structure. If you take out enough wood from the top to make it really responsive, it will collapse due to cold creep way too soon. A well designed bracing system incorporating CF has a monopole mobility (a measure of responsiveness) approximately 50% higher than typical wood-only braced guitars. (That's data from my measurements of monopole mobility from ~20 big and small brand name SS guitars)
Please discuss!
DennisK wrote:
Please discuss!
Wow, that's quite a difference! Does make sense though. You can make the top quite flexible before the bridge over-rotates right off the bat. And then cold creep is the only real problem.
Maybe I'll try laminating up some braces and peel the top off my prototyper for some experiments. I think I'll do just the X, since that's the big stress taker, and would save a lot of effort laminating for all the other braces and resharpening as they eat the chisel. Not looking forward to getting CF dust all over the place though...
I do have a tendency toward organic materials (even the common adjustable truss rod irks me a bit), but top bracing seems like one of the best places to sacrifice romance for practicality. Plus if I can get my tops to a relatively high level of creep resistance, I can use integral necks, which I like for various reasons :)
David Malicky
PostPosted: Thu Sep 29, 2011 1:03 am
First name: David
Last Name: Malicky
For some points of reference, and because creep takes a long time to test, are there any historical guitar models that are especially known for being prone to creep (sunken soundhole and/or bottom bellying)? And, any models that have been resistant to creep?
David Malicky
PostPosted: Thu Sep 29, 2011 8:31 am
First name: Trevor
Last Name: Gore
City: Sydney
Gibson guitars with the pre-profiled X-braces that make the lap joint look like a butt joint. The tops cave in, but this is as likely to be failure of the so-called joint as much as creep. D35s (0.25" bracing) used with 13s, but the 13s don't seem to be totally necessary to precipitate a problem. Older guitars that still look good are the ones that still have a high top curvature(!), because they were built that way initially e.g. some of the Larson Bros. models, a very rare beast in these parts though, so hardly a statistical sample.
http://www.goreguitars.com.au
PostPosted: Thu Sep 29, 2011 9:07 am
City: winnipeg
State: manitoba
Country: canada
I don't wish to derail this thread but having access to Trevor Gore allows me to ask this question, Does falcate bracing have any acoustic properties or is it strictly structural? In building baritone ukuleles, the string tension is not a major problem but stiffer bracing might allow a thinner (lighter) soundboard.
Any opinions?
Bob :ugeek:
PostPosted: Thu Sep 29, 2011 9:39 am
I thought that all of the acknowledged "killer" pre-war Martins had pronounced "bottom bellying" - what an evocative phrase :shock: . Is it necessarily a bad thing if the guitar remains with good playability and in fact may it be a good thing soundwise? Good point about the Larson brothers guitars Trevor with their top arching pre-built in without waiting for it to develop. Also the cylindrical top arched Howe-Orme guitars of the late 19th early 20th century.
PostPosted: Thu Sep 29, 2011 3:21 pm
Carbon fiber reinforced bracing is quite interesting I think. It's also quite interesting how most guitar makers are using it.
The typical usage as I've seen it, uses CF sandwiched between to pieces of spruce so that the CF runs perpendicular to the top. This is actually the least effective use of CF in terms of adding stiffness to the structure. However, those that are using it say that's o.k., they're using the CF not to increase the stiffness of the structure but rather to eliminate the cold creep of wood.
From a stiffness standpoint, capping the brace would provide the most resistance to torque and the stiffest brace. This however has the effect of eliminating the ability to remove height from the brace to control stiffness (this also is the argument against I beaming braces as well). But, if you're not shaving your braces that becomes a non issue. It also means that unless you have a square brace that's only got a straight taper, it would be quite difficult to scallop braces if that's your thing.
edit: Just to put a fine point on it - generally speaking, the load on any beam is borne by the most proximal and most distal surfaces, the inner "stuff" just connects those two surfaces. The reason I mention it is because of my statement above about the stiffest brace being one capped rather than sandwiched. The capped brace will be stiffer in one plane, but close to the same as a solid wood brace in other planes.
PostPosted: Thu Sep 29, 2011 7:45 pm
First name: Trevor
Last Name: Gore
City: Sydney
David82282 will be after you if you derail this thread!
Falcate bracing can be quite efficient structurally, so it can give more stiffness for less mass, which you can use to acoustical advantage.
PostPosted: Fri Sep 30, 2011 1:56 am
First name: David
Last Name: Malicky
Thanks, Trevor and Dave, for the historical info. If not bottom bellying, what do you think about over-rotation of the bridge? Sounds like high curvature is quite effective.
No worries on derailing... threads naturally beget themselves.
Andy, yes, carbon fiber is interesting, and using as 'web' or 'flange' makes a huge difference to the moment of inertia. Also the shaving feasibility as you point out. That's also interesting that most use it as 'web' to prevent creep. I'm wondering, given the low shear strength of wood (~1/5 of longitudinal), whether a CF cap/'flange' (on top a wood brace as the 'web') might be so stiff as to cause a shear problem in the wood. Looks like E_cf_uniaxial is about 16x E_wood, which makes for a hefty effective flange. I rarely see a beam limited by shear strength, but this one has potential. To find the shear load (V)... maybe resolve the bridge moment into down and up forces (a couple) near the front and rear edges of the bridge, where it crosses over the braces.
Does anyone know how much wood cold-creeps in shear vs. longitudinal?
For those using CF as the 'web', how thick is that layer, typically? I wonder how much the adjoining wood contributes to the total E*I. I can see it helps the glue area to the top a lot, and probably helps customer acceptance?
David Malicky
PostPosted: Fri Sep 30, 2011 3:10 am
Good point.
Not to hijack the thread again, but FWIW I was looking at the possibility of Balsa/CF for braces, and Googling "best glues for Balsa to CF" came up with aeromodelling forums indicating that CF capped spars are best spirally wrapped over the CF layer with some kind of thread - I found CF, polyester, even dental floss(unwaxed!) is suggested to help prevent delamination.
Spiral wound braces anyone?
(Probably steel strings are out for balsa braces because of the weakness of the wood to shear forces, although used by some classical builders with CF lattices, Greg Smallman for example)
PostPosted: Fri Sep 30, 2011 3:59 am
Filippo Morelli wrote:
Dave White wrote:
... had pronounced "bottom bellying" - what an evocative phrase :shock: . Is it necessarily a bad thing if the guitar remains with good playability and in fact may it be a good thing soundwise?
No.
Filippo
Why?
PostPosted: Fri Sep 30, 2011 12:10 pm
Last Name: Ulman
City: Bellevue
State: Washington
Please excuse my ignorance on the subject but could someone define the terms ‘creep’ and ‘cold creep’ as they pertain to wood in guitars? Thanks.
Joe
PostPosted: Fri Sep 30, 2011 2:31 pm
Joe
Plastic deformation over time. i.e. a piece may deflect a certain amount under a certain load but over time, it will deflect more and will not return to its original configuration when the load is removed.
I think we use the term cold creep because as we all know, wood can be plastically deformed quite easily with the application of heat.
PostPosted: Fri Sep 30, 2011 3:32 pm
Last Name: Ulman
City: Bellevue
State: Washington
Thanks Andy… makes perfect sense.
Joe
PostPosted: Fri Sep 30, 2011 9:34 pm
First name: Trevor
Last Name: Gore
City: Sydney
Balsa will fail in shear on lattice braced classicals if the balsa substrate is not chosen appropriately. The ranges of stiffness, density and strength is huge in balsa, so be very careful. Spiral winding done properly is a potential solution. I do some analysis in the usual place on composite braces. For steel strung instruments I concluded that by the time you had enough balsa in there to take the shear you'd be better off (less mass) using something else, e.g. spruce.
Using CF obviously limits what you can do in terms of "after the event" brace shaving. That's why I came up will a bunch of alternatives so it is still possible to tune modes without having to hit the braces.
Over-rotation usually leads to an eventual failure, with the bridge or bridge plate or both detaching. I try to limit bridge rotation to ~2 degrees, which puts you in the right ballpark on both classical and SS guitars to hit the preferred modal frequencies. If you start with the right amount of curvature in the top, 2 degrees of rotation is possible without precipitating a reverse curvature, so you avoid the roller-coaster effect, which I've never found to be a great selling point! There's a chart in the book which shows how the natural frequency of a plate varies with curvature.
PostPosted: Sun Oct 02, 2011 12:55 pm
FWIW, a reference I saw in some homebuilt airplane literature suggested that the initial deformation under the design load limit should be no more than 1/3 of the acceptible long term creep deformation for wooden aircraft structures. In other words; if your aircraft weighs 1500#, you're designing to +3.5 Gs, and you can't stand to see the wing tips come up more than, say, a foot, then you should see no more than four inches of delfection when you load the wing with 5250# of sandbags. On a guitar, you could put on 'heavies' and measure the deflection in front of the bridge: much less work. Over time, you might see as much as three times that much deflection in that spot with the same strings.
IMO, glue creep is a much bigger factor than wood creep in tops: PVA and AR glues don't stay put for long when subjected to shear loads.
PostPosted: Sun Oct 02, 2011 6:39 pm
First name: Trevor
Last Name: Gore
City: Sydney
Hmmm, interesting! I've never had a problem gluing on bridges (SS and CL) with Titebond (AR glue). Perhaps method is at least as important as materials here.
PostPosted: Sun Oct 02, 2011 7:43 pm
The only guitar I have owned which experienced a bridge failure is a 1975 guild 12 string which I have have owned from new.
As far as I know it was never subjected to heat stress and shows no other damage.
The bridge didn't lift but slid forward about 1.5mm until the bridge pins stopped it.
That one example was enough for me to avoid AR type glues for bridges.
PostPosted: Sun Oct 02, 2011 8:56 pm
One former student, who worked for Guild, said that they used PVA because a 5 gallon bucket was $5 cheaper. I, too, have seen a few bridges on factory guitars with narrow line of bare wood behind, and a small ridge of finish in front. I never had any such problems when I used Titebond on my own instruments: as you say, probably technique and surface prep make a lot of difference.
I once had to replace a bass bar on a violin that had been glued in with PVA. The bass side of the top was nearly flat, but the ends of the bar were still glued down; it had just slid. I had quite a time getting some arch back in that top. Since then I've regarded PVA as the equivalent of chewing gum: it doesn't really hold anything, but you can't get it loose, either.
Titebond and that ilk are a decided improvement, but not 'creep free'. I have noticed that since I started using HHG for top bracing I've seen less deformation in my tops, and I'm making them a bit thinner now than I used to.
PostPosted: Sun Oct 02, 2011 10:09 pm
First name: Erik
Last Name: Hauri
State: Maryland
When doing stiffness and mass calculations for CF constructions, remember that many CF products are actually epoxy-impregnated CF composites. And it is not at all obvious to me that the various moduli (and densities) I've found quoted for "carbon fiber" are for actual pure carbon fiber, or specific epoxy+CF composite material(s). idunno
The member formerly known as erikbojerik....
PostPosted: Sun Oct 02, 2011 11:24 pm
First name: Trevor
Last Name: Gore
City: Sydney
Erik raises a good point. Whichever way you choose to use CF, either as strands or preformed laminates, you're probably better off "dummying up" a brace and testing it rather than relying totally on calculations.
PostPosted: Mon Oct 03, 2011 3:06 am
My "no" was in regards to your "bad thing" question. Do you think it is a bad thing? There are plenty of classical luthiers that like to see that kind of movement - a bit of belly and some brace shadowing. Then there as those that don't. But to your question of whether it is necessarily a bad thing, I don't see why not. As to the latter part of your compound sentence, I would say yes. (so you asked two questions in one compound sentence that have potentially contradicting answers 8-) )
Filippo
Sorry Filippo - as you rightly say my question and your answer was confusing myself. I don't think it's a bad thing and I do think it's a good thing soundwise.
Users browsing this forum: DennisK and 55 guests
