It is currently Tue Aug 19, 2025 8:09 am
 Post subject: Motor Ganging
PostPosted: Thu Jan 19, 2012 6:09 am
I'm in the process of building a thickness sander. I'd like to make a larger drum than say the typical 5". This to keep more paper in the game thus keeping it cooler and cleaner. I have a bunch of ½ hp electric motors and something occurred to me about ganging 2 ½ hp motors together, not necessarily that I would need them after gearing down the sanding drum to meet appropriate SFM (surface feet/minute). Just curious if there's a problem with this.
Any comments?
 Post subject: Re: Motor Ganging
PostPosted: Thu Jan 19, 2012 8:20 am
First name: Coe
Last Name: Franklin
City: Decatur
I made a thickness sander a few years ago that has a 9" diameter powered by a 1/3 hp motor.
The pulley on the drum is actually a groove cut into the drum itself about an inch in from the side to accept the v-belt. A 2" pulley is on the drive motor.
When I did the math and calculations, I came up with about 900 rpm at speed. I don`t remember what the estimated hp is at the drum, but it takes effort to stall it out. It works very well.
If you`re wondering about the construction of the drum, I used a pine 2x12 and laminated the pieces onto a 3/4 steel shaft in a cross-grain orientation. Yes, it`s heavy, but IMHO, the wieght helps it run smoother and being so large, runs somewhat cooler.
My pics of it aren`t around anymore and I have it disassembled because I no longer have the real estate in my shop/spare bedroom, and I`m not crazy about using that dust maker in the house, as it can get pretty bad in an enclosed area, even with dust collection.
I only use 80 grit paper on it made from a used belt from a wide belt sander.
Speaking of width, I made the drum 24" on the abrasive plus whatever else on the ends.
I also built the sander to accept up to 4" (IIRC) and down to .010". That way it takes pretty much whatever I feed into it (within reason, of course).
Sorry about being so long-winded about this, but I truly miss having it set up and ready to go, hence a severe slow-down in my production.
I`ve actually been trying to come up with some sort of idea to get it set up again.
Coe Franklin
PostPosted: Thu Jan 19, 2012 1:58 pm
First name: David
Last Name: Malicky
Zip/Postal Code: 92111
It's generally not a good idea to gang motors--differences in their torque-rpm response and belt-pulley fit (pitch diameter) cause one motor to do most of the work.
David Malicky
PostPosted: Thu Jan 19, 2012 2:36 pm
Don't be sorry bout that! You're giving a lot of empirical information. I could only imagine having to use something like a 9" sander in the house! I was actually thinking about going even bigger like 10"-12".
Now I'm thinking about better dust collection. Even though I'll probably be using mine outside.
I know with cars that's the way it is. All these double engine'd dragsters from the 50's and 60's never did really well for that same principle. I was just wondering if the same thing applied to torque itself. Electric motors and internal combustion engines have a whole different performance parameter. Vis-a-vis, electric motors have full torque at 0 RPM, where as internal combustion has to be wappped up quite a bit to get anything close to full torque.
PostPosted: Thu Jan 19, 2012 4:55 pm
First name: David
Last Name: Malicky
Yup, with AC induction motors, torque is generated by a small % slip from the base frequency, and torque is very sensitive to slip. For example, a 1725 rpm motor develops its rated torque at a slip of ~4% from its 1800 rpm base. If it slips 3%, it generates a lot less torque, or 5%, a lot more. Graphically, the problem is that the curve is very steep at rated (full load) torque:
http://www.engineeringtoolbox.com/elect ... d_652.html
Direct drive (with couplings) could be used to match the rpms exactly, but motor models don't have identical slip-torque curves, so they'd still fight each other (maybe with high quality motors, identical builds, it could work--I don't know.) As with dragsters, so go sanders!
David Malicky
Users browsing this forum: bobgramann, rbuddy and 39 guests
