It is currently Sat May 09, 2026 6:32 am
 Post subject: polymerized tung oil ??
PostPosted: Sun Jan 22, 2012 12:25 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
33 years ago I made a plastic hammer using a birch handle finished with tung oil. The finish is still there.I called dicks and ace hardware neither has tru-oil,My question for all you OLF ers out there , have any of you used tung oil to finish an acoustic gtr neck.? Have used tung oil in cabinetmaking, but never for gtr construction. I realize that the tru-oil is a type of vy thin oil based varnish, wheras the tung oil comes from a tree. Your thoughts please ??
PostPosted: Sun Jan 22, 2012 1:06 pm
First name: William
Last Name: Snyder
City: Brooklyn
If you don't mind waiting a few days, lmi sells tru oil:
http://www.lmii.com/CartTwo/thirdproduc ... Oil+Finish
Amazon, too:
http://www.amazon.com/Birchwood-Casey%C ... 539&sr=8-2
PostPosted: Sun Jan 22, 2012 1:19 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
You could do some research,
and mix up your own.
PostPosted: Sun Jan 22, 2012 1:21 pm
I posted this in another thread, but you can buy Tru-Oil directly from Birchwood Casey.
PostPosted: Sun Jan 22, 2012 3:53 pm
First name: Adam
State: Oklahoma
I asked the same questions a few weeks ago. I can't remember the thread name, but several OLFers said they used tung oil on necks but not bodies as they thought it would be impractical with the lengthy cure time and amount of surface area.
Hope that helps. I'll try and dig up the thread if I can find it.
Adam
PostPosted: Sun Jan 22, 2012 4:02 pm
First name: Jim
Last Name: Hansen
I'm sure it's been posted here before.
Check out this thread at the gear page forums. Especially by the poster named "Quarter".
http://www.thegearpage.net/board/showth ... p?t=711780
Jim Hansen
PostPosted: Sun Jan 22, 2012 4:17 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Was planning to use tung oil only on a stained cherry neck.Body gets laquer
PostPosted: Tue Jan 24, 2012 1:57 pm
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
This is what I use on my paddles, and I've made many hundreds of them.
1 sealer coat of varnish. I use Epiphanes thinned 50%.
Dry one day, sand with 220 paper, apply 1 coat of tung oil with 0000 steel wool. Buff with clean cloth.
Next day, apply 1 coat of tung oil with 0000 steel wool. Buff with clean cloth.
Done.
Oh, and most of those paddle shafts and grips are Cherry.
http://redrivercanoe.ca/
PostPosted: Tue Jan 24, 2012 6:05 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Hi doug have you used this method varnish/tungoil on gtr necks?/have some behlens rock hard that can be thinned? My canoe paddles were carved from doug fir.
PostPosted: Fri Jan 27, 2012 9:01 pm
First name: Chip
Last Name: Hunter
State: New Mexico
I'm betting that Bob's Gun Rack in Lees Summit stocks it, it is found in nearly every gun store.
PostPosted: Fri Jan 27, 2012 11:16 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
What if you live in a country where guns are illegal because the government can't trust us enough?
Typhoon Guitars
PostPosted: Fri Jan 27, 2012 11:34 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Consider yourself blessed!
Alex
PostPosted: Sat Jan 28, 2012 12:57 am
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
No, but I wouldn't hesitate to do so. I've been putting shellac over varnish.
Users browsing this forum: Cal Maier and 12 guests
