It is currently Sat May 09, 2026 5:24 am
 Post subject: Changing Saddle & Nut
PostPosted: Fri Jan 27, 2012 12:26 pm
First name: Florentin
Last Name: Tise
City: Chicago
I've had this Alvarez AC60S for a couple of months.
I bought it on eBay in what appears to be NEW condition.
Great guitar, but there were quite a few buzzes, especially on the first three strings, in the higher frets, especially when playing apoyando (rest stroke).
At first I thought it was a neck-angle issue.
The instrument does come with a truss rod, even though it is a classical.
So I measured the action at the 12th fret.
Of course, I measured it wrong, so I became very confused.
I put the guitar away, not knowing what to do. I did not want to goof it up.
After joining this forum, I gathered the courage to take it out again, and try to solve the problem.
I did tonight. At least I think I did :O)
First, I measured again. Of course, I had measured wrong before.
I had measured in a hurry, and did not use a precise ruler. Also, I measured from the top of the fingerboard, instead of the top of the fret. Go figure :roll:
What I thought was a 5mm and 4mm action (sixth and first strings respectively) turned out to be a 3.5 mm and 2.5 mm action. No wonder the poor thing was buzzing.
I had ordered some bone nuts and saddles, and tonight I changed the old ones with the new, filing the new ones to a better dimension.
The new setup is WONDERFUL. There is not one buzz anywhere on the guitar, even when I play the heaviest of a rest stroke. A very sweet sound also. The sixth string at the 12th fret is at 4.5mm and at the 7th fret it is 4mm.
Here's the old saddle - you can see how low it is, especially on the treble side...
Here are the new blanks...
After some filing...
The new nut...
With the strings on... a couple of the slots have to be made a bit deeper.
Here she is...
I recorded a short piece after the new setup, but I am not crazy about the sound quality. Sounds much better live.
I bought this new Blue SnowBall microphone, but I can't seem to find the right balance for it. Sounds too muffled and the basses are not live enough.
Boy, I look like a zomby at 3AM in the morning :O)
Music Is Forever
PostPosted: Fri Jan 27, 2012 1:15 pm
First name: David
Last Name: Morris
City: McKinney
It always feels good when you reach a point that you're able to diagnose a problem and fix it when you once weren't. Good work.
David Morris
PostPosted: Fri Jan 27, 2012 1:20 pm
Last Name: Tise
City: Chicago
The guitar sounds incredibly better!
The action is still a bit high for my taste, but I can bring it a tiny bit lower next time I change the strings.
Thanks for the comment.
Music Is Forever
PostPosted: Fri Jan 27, 2012 2:08 pm
City: chicagoland
State: illinois
nice playing! i am envious
can't you just loosen the strings off and slide the saddle out to work on it? thats what i do
PostPosted: Fri Jan 27, 2012 2:15 pm
Last Name: Tise
City: Chicago
thanks
I probably will loosen the strings and lower the action a bit more.
It is not too high for a typical classical, but I've been playing on a Flamenco model for a while, so it feels a bit different.
I do like the ability to dig into the string though, so I won't go too low on the action.
Music Is Forever
PostPosted: Fri Jan 27, 2012 2:37 pm
State: Tennessee
Good fix. Nice sounding guitar, you play it well.
I have a nice Taylor nylon string cutaway that I need to play more than I do. (That Telecaster keeps me busy)
PostPosted: Fri Jan 27, 2012 3:37 pm
Last Name: Tise
City: Chicago
Thanks.
I know that compared to the work of others in here, this project is nothing, but for me it was very exciting.
Learning a lot in here.
Music Is Forever
PostPosted: Fri Jan 27, 2012 6:08 pm
First name: Gene
Last Name: Zierdt
City: Sebastopol
Zip/Postal Code: 95472
Beautiful playing, and the guitar sounds great also. You better
be careful reading about building guitars...it's a terrible addiction
once you give in bliss
Gene
PostPosted: Fri Jan 27, 2012 8:19 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
Nice playing!
[clap] [clap] [clap]
PostPosted: Fri Jan 27, 2012 11:45 pm
Enjoyed your playing! [clap] If you're unhappy with your recording tone, may I suggest moving the mic to different locations? On some mics I find that if I point the mic towards the fretboard, it cleans up the highs. Clinton
PostPosted: Sat Jan 28, 2012 1:55 am
Last Name: Tise
City: Chicago
Thanks for the comments.
I've had the SnowBall for about a week now.
I am still trying different setups and different positions.
I haven't found one variation that satisfies me yet.
Music Is Forever
