It is currently Mon May 18, 2026 12:06 pm
PostPosted: Wed Feb 22, 2012 10:44 am
Last Name: coloccia
Country: States
Anyone see a problem doing this? It's a 2 way rod so I can't imagine it makes any difference which side is up. It's going into a Fender style neck, and after mulling over my options for truss rod access, I decided on a traditional heal access but was thinking I'd put the Allied Lutherie rod in upside down to allow access with the neck bolted on (it puts the nut at the top instead of the bottom.
PostPosted: Wed Feb 22, 2012 11:31 am
First name: Danny
Last Name: Vincent
I would be asking that question to Allied. He knows best.
PostPosted: Wed Feb 22, 2012 11:33 am
Last Name: coloccia
Country: States
I will as soon as they open, but they're in CA so I thought I'd try here first. I'm twiddling my thumbs waiting to make a batch of necks. :)
PostPosted: Wed Feb 22, 2012 11:37 am
First name: Corky
Last Name: Long
City: Mount Kisco
Don't think it will work. Even though it's a two way truss rod, it's designed to apply most of the force in one direction (assuming the two way rod is what I'm accustomed to using, a round threaded adjusting rod, under a flat metal "spring" for want of a better term.) The rod turns and flexes the spring to provide the tension to counter tension of springs. Turn in the other way and the spring goes concave. I don't think it provides near the same tension in "concave mode". My two cents - YMMV.
PostPosted: Wed Feb 22, 2012 1:10 pm
I think the only "issue" might be in having a non-conventional direction for turning the nut when making adjustments. If whoever is doing the adjustment is not aware that the truss rod in this guitar works "backwards" they may do some damage before they figure out what's going on.
I don't agree with Corky's spring theory but perhaps I just don't understand what he is saying.
PostPosted: Wed Feb 22, 2012 1:13 pm
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
Personally. I think it's not a great idea for the reasons already mentioned. Also... The flat, top bar spreads the load under the fingerboard better than the rod will... Even if you glue a thin filler strip over the truss rod.
I have to ask... Why do you want to put the rod in upside down?
PostPosted: Wed Feb 22, 2012 1:21 pm
Last Name: coloccia
Country: States
I called Allied and we spoke about it a bit. After we scratched our heads for a couple of minutes, he made an excellent point that it puts less bearing surface against the FB, and could potentially split it. I would really have to bury it a bit deeper and use a thicker filler strip but that defeats the purpose. We both agreed that it should work just fine, though. Upon thinking about it some more I decided that the backwards turning rod coupled with dubious gains in nut position just makes the whole thing not worth it.
PostPosted: Wed Feb 22, 2012 1:23 pm
Last Name: coloccia
Country: States
Having the rod upside down moves the nut a bit closer to the FB, making it easier to adjust without removing the neck...also if I wanted to make this a set neck.
Instead, I will just cut a recess in the body at that point and supply a stubby wrench with the guitar. That should work fine.
PostPosted: Wed Feb 22, 2012 2:58 pm
If this is true somebody better tell Stew-Mac to re-design their "Hot Rod" truss rod.
PostPosted: Wed Feb 22, 2012 3:04 pm
Exactly what I was thinking. :mrgreen:
PostPosted: Wed Feb 22, 2012 3:34 pm
A two way rod works both ways and if the round rod will split a fretboard, it could also split the back of the neck right? So there would not be a difference. ;)
PostPosted: Wed Feb 22, 2012 4:26 pm
First name: Freeman
Last Name: Keller
Here is a SM hot rod style t/r adjusted perfectly flat
and with one turn on the adjuster
(I like to show those to people who say "just give the truss rod a turn or two")
In their instructions, StewMac says " The Hot Rod® fits in a straight channel. For proper operation, this truss rod must be installed so that the active rod (the rod with the adjustment nut) is below the passive rod. A wooden filler stick is not required"
PostPosted: Wed Feb 22, 2012 7:47 pm
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
Mark makes an excellent point... Which I thought out AFTER I posted my last note.
Duh.....
PostPosted: Wed Feb 22, 2012 8:29 pm
Last Name: coloccia
Country: States
Well to be fair, once it dawned on me that the rod would work "backwards", I decided to kill the idea so I didn't really put much thought into the rod pushing against the fingerboard and whether or not that would be OK. The fact is that the nut position moved so little that it's just not worth the trouble to have a backwards rod.
PostPosted: Thu Feb 23, 2012 6:58 am
First name: Kent
Last Name: Fishburn
City: Woodstock
State: Illinois
I've owned several National guitars. Not sure if they are all this way but the truss rod in the "tricone" and the "N" that I had worked backwards. Very confusing the first time I had to work on the action.
Kent
PostPosted: Thu Feb 23, 2012 9:59 am
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
EDIT :post now redundant ...
PostPosted: Thu Feb 23, 2012 11:55 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I hate truss rods that adjusts in 2 directions... if the neck wood is properly dried and selected such a rod isn't needed anyways.
I had adjusted a Takamini G series guitar that has such a truss rod, but I wasn't aware of it so I just turned it and it felt it was tightening but it wasn't until the customer noticed that the neck was becoming more concave that I stopped and turned the other way. I was lucky that I didn't end up damaging the neck.
Typhoon Guitars
PostPosted: Thu Feb 23, 2012 12:22 pm
First name: Freeman
Last Name: Keller
murrmac wrote:
Just to show the second pic (wrong IMG bracket, "{" instead of "[" ) ...
Fixed
Users browsing this forum: No registered users and 418 guests
