It is currently Tue Jun 17, 2025 12:00 pm
PostPosted: Wed Feb 29, 2012 7:42 am
First name: jim
Last Name: daniels
City: fayetteville
State: nc
Zip/Postal Code: 28306
is there a set of plans for building a steam producer or what do I use to take the mandolin apart? I have a hand held torch or will a household steam iron work? thanks jim
PostPosted: Wed Feb 29, 2012 8:30 am
First name: Corky
Last Name: Long
City: Mount Kisco
Do you have an old cappucino maker? They work perfectly - clamp a hose onto the "milk frother"attachment and you've got a steamer, perfect for loosening necks, etc.
PostPosted: Fri Mar 02, 2012 4:24 pm
+1 to what Corky wrote. I use the StewMac steamer tube and tip with my milk frother.
StewMac hose/needle here
Of course others have used a heat resistant tube from your local auto parts store and a basketball(or other ball) air needle.
Chris Oliver
Infinity Luthiers
...in the shop.
live every minute...
PostPosted: Sat Mar 03, 2012 1:05 am
Last Name: Shaw
City: Philadelphia
State: PA
Zip/Postal Code: 19125
I use a krupp espresso machine I picked up at a thrift store for $8. And I bought some high pressure hose at the car parts store and a football/basketball inflation needle and some small hose clamps.
Another day, another dollar.
PostPosted: Sat Mar 03, 2012 8:08 am
Last Name: Matthews
State: Surrey
Country: England
I use a wallpaper stripper, a flexible rubber hose with a needle from a football pump for doing neck resets, I'm sure it's overkill as the coffee maker sounds perfect, but it's what I had to hand when i did my first reset.
I haven't had the need to use steam for anything else, but some luthiers will use it for gluing on backs and sides with hide glue. Here's an advocate. http://www.thestrad.com/pdfs/hamtradesecrets.pdf
http://www.bobmatthewsguitars.co.uk
PostPosted: Sat Mar 03, 2012 8:50 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
Some folks use special gaah gaah gloves when working with steam.I used them when bending long arm bows for making chairs.Steam burns are nasty.I speak from experience.
PostPosted: Sun Mar 04, 2012 12:29 am
Last Name: Shaw
City: Philadelphia
State: PA
Yeah Ernie is right about burns. I burned myself slightly when I first started experimenting with the espresso machine.I don't know if my gloves are special but I just wear these smooth leather work gloves that I have....Mike
PostPosted: Sun Mar 04, 2012 12:34 pm
Last Name: Ellis
City: Manteca
Zip/Postal Code: 95337
I use my wife's Iron with the steam burst option. I know it doesn't get into all the little places, but I sure enjoy watching her freak out that I'm using her iron. beehive
PostPosted: Tue May 08, 2012 12:50 pm
First name: Jamie
Last Name: Martus
City: Leonard
Country: U.S.
Old cappicino machine! if you really need steam.
Personally i only use steam on delicate vintage insturments, or for neck removal.
Mix up a glass of hot water, denatured alcohol, & a couple drops of dish soap and inject it into the seam with a syringe. Or wet the kerfing & glue from the inside. Im not talking about soaking it, just enough to soften the glue a bit.
Take your time with a couple of disassembly knives (stew mac) or pallette knives from art supply store. Work slowly and watch where your tool is going.
As always it's best to practice on a couple of junkers 1st.
